~~~ PARTING OUT!!! 500+whp turbo kit, tranny, exedy, aem, garrett, slicks, LOOK!
Old Jan 10, 2007 | 08:37 PM
dunkd's Avatar
Default ~~~ PARTING OUT!!! 500+whp turbo kit, tranny, exedy, aem, garrett, slicks, LOOK!
I have tons of vouches on here and a great ebay feedback rating. I can accept paypal, but you must add three percent. I would just prefer money orders or checks. Shipping is not included on the prices, would prefer local pickup on bigger stuff. Ask me if you want any specific pictures. I am going to start with the bigger stuff on ebay so check my items for sale: http://search.ebay.com/_W0QQsassZamydelsolQQhtZ-1
All of these parts came off my running Civic, so everything is in good working condition. Most parts have around 1,000 miles on them. Car made 527whp @ 25psi on c16, setup ran 11.1 @ 132 at ~450whp last year, pump gas & interior. EVERYTHING IS FOR SALE!!!
Email cgunsch@gmail.com, PM me, or catch me on AIM @ 'paintballs'. I am located near 12601 Poughkeepsie, NY. Can meet up for bigger stuff if reasonable.
Do not lowball me, I will just ignore you.
235/60/15 Mickey Thompson ET Street radials mounted on gunmetal Drag dr16 wheels, tires have 500 miles and in great shape. Matching 16” gt3's for the back with new Kumho tires. - $750
95 GSR block- has mains, but bare otherwise, needs to be sleeved - $200
ATI Super Damper crank pulley, needs to be fixed - $80
Tapped GSR Oil pan - -8an return fitting, comes with newer reusuable gasket $50
A-Pillar 2 Gauge Pod - $15
Rear civic mount with ES insert - $20
95 GSR Black 2dr Rear Seats - $60
JDM Stanley EG Sidemarkers, has bulbs, no male side connectors though. - $20
(1) 6000k Hella HID Bulb - $30
92-96 Prelude taillights - $25
SOLD!!!
1997 Acura Integra GSR B18C1 Cylinder Head - Aftermarket valves, springs, and titanium retainers. I was told they are Skunk2. 50K on the head, 7k on the valvetrain. Head comes with GSR cams and stock gears. Everything except for the dizzy, intake manifold, and valve cover. sold
Polished JG Edelbrock Intake Manifold - sold
Hondata plastic intake manifold gasket, reusuable forever - sold
GSR Throttle Body, throttle cable bracket, oem MAP and TPS - $100pending
MSD Pro Billet Distributer, SC External Coil, obd2-obd1 dizzy adapter harness, coil wire, NGK Blue spark plug wires. 1000 miles, never had a single problem, cleared up my ignition problems. - $sold
Precision 1000cc Injectors - sold
AEM Fuel Rail with Autolink liquid filled fuel Pressure gauge - sold
Aeromotive FPR, comes with -6AN fittings and steel braided feed/return lines - sold
CP 9:1 pistons, 84mm, 500 miles on them, good shape, comes with original box- $sold
Manley turbo-tuff rods, one spun a bearing, could be fixed with hone? worst case need one rod - $sold
Golden Eagle Head Studs, One year old - $sold
Endyn external oil catch can system, comes with all fittings and hoses, like new - sold
PWR Aluminum Radiator for EG civic, like new - sold
Fal slim fan, red, plastic melted on side from downpipe - sold
Walbro 255 HP Fuel pump, 500 miles on it, bought this year - sold
2000 B16 Transmission with Quaife LSD, no grinds. I bought it as is and was told it has about 60k on it and 10k since the Quaife was installed. - sold
Z10 Engineering traction bars, for an EG chassis, comes with all original hardware and brackets to install - sold
Innovative Race Urethane Motor mounts, black wrinkle powdercoat, made for a B-series into an EG, three post timing side mount, used for 1k miles - sold
GM 3Bar MAP sensor, comes with pigtail and extended wires - sold
GM Boost control solenoid w/ harness - sold
Autometer 5” Tach, comes with shiftlight- $sold
Autometer phantom series Boost gauge, comes with nylon tubing - sold
Garrett T3/60-1 .62/.70ar, 4bolt exhaust flange, no shaft play, good seals, made 450 @ 18psi, 527 @ 25psi - $sold
Spearco FMIC, very good condition, 32”x8”x3.5”, 2.5” inlet/outlets - $sold
CRFab Equal length turbo manifold, T3 and 38mm flanges - $sold
CRFab 3” Stainless downpipe, 4 bolt, flex section, two o2 bungs, no exhaust flange, correct length - $sold
Tial 38mm wastegate, silver, comes with banjo fittings and dumptube flange - sold
2.5” Custom Intercooler pipes and TurboXS style blue BOV, 4 pipes, all silicone couplers and 12 T-bolt clamps - $sold
Oil feed and return, -3 x 3ft feed, -8 return w/ AN fittings, turbo return flange, just need block T fitting - $sold
3” testpipe w/ new band clamp- $sold
gsr wire harness - sold
intermediate shaft - sold
rear t bracket - sold
shift linkage - sold
starter - sold
Kteller 3” mild steel catback for EG 2/4dr, comes with all hardware, Magnaflow 3” polished muffler - $sold
Ferio trunk emblem - $sold
Ferio door garnishes - $sold
AEM EMS 1000 box, v1.19 firmware installed, comes with datalog cable - $sold
PLX M300 wideband, comes with two working o2 sensors both have <1k miles on them - $sold
2000 GSR block - $sold
Rota's - $sold
Shaved Bseries DOHC VTEC valve cover, - $sold
95 GSR Wire Harness - $sold
95 GSR Alternator - $sold
99-00 Civic Si front lip - $sold
GSR windage tray & oil pickup - $sold
Autometer oil pres gauge - $sold
lower torque mounts w/ brackets and ES inserts- $sold
air filter, fuel line, power harness - $sold
Bogart Drag-on Fly Stars with 24.5x8.5x13” M&H slicks - sold
(2) VX wheels - $sold
Exedy Twin Disc Clutch - $sold
JDM EG Ferio front and rear seats, rear center console, blue/grey - $sold
JDM Power Folding Mirrors with oem switch and relay - $sold
Tial 38mm wastegate spring - .6bar 8.7psi - $sold
Bseries Dohc Vtec Crank Pulley, great condition - $sold
The Shell - sold
20x8x13” slicks -sold
Modified by dunkd at 4:14 PM 3/31/2007
Old Jan 10, 2007 | 09:12 PM
amy's Avatar
amy
no sell.
Old Jan 10, 2007 | 09:42 PM
shifts's Avatar
Default Re: (amy)
bump for interest.
Old Jan 10, 2007 | 09:56 PM
Bonez21's Avatar
Default Re: (shifts)
Wow, didn't expect to see this anytime soon
Old Jan 10, 2007 | 11:20 PM
JDMH22HATCH's Avatar
Default Re: (Bonez21)
Best of luck with the sale buddy. Its sad to see this car parted out
Old Jan 10, 2007 | 11:32 PM
dunkd's Avatar
Default Re: (JDMH22HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH &raquo;</TD></TR><TR><TD CLASS="quote">Best of luck with the sale buddy. Its sad to see this car parted out </TD></TR></TABLE>
thanks man, im gonna give something new a try... i'll prolly be back to a turbo EG again eventually. I bought this car four years ago and its been a project ever since. I've pretty much done everything I've wanted to do to it so time for something new.
Modified by dunkd at 3:47 AM 1/11/2007
Old Jan 11, 2007 | 12:10 AM
I Have an STD's Avatar
wrenchin'
Default Re: (dunkd)
wow, i knew this day would eventually come. if i can come up with some cash i'm interested in, well, everything. i'll let you know. if nothing else, good luck with everything cody, i know how much time/money/effort you have into this car. what are you doing next anyway? if you dont wanna post it, im me or pm me
everything here is 100% top notch stuff guys! buy it up!
Old Jan 11, 2007 | 02:20 AM
Cain Marko's Avatar
Rotary Lift Specialist
Default Re: (amy)
why god why!?
So whats in the future for you cody?
Old Jan 11, 2007 | 02:59 AM
japspecjohn's Avatar
Default Re: (Cain Marko)
bump for a cool dude in a loose mood
Old Jan 11, 2007 | 03:34 AM
ivt-t's Avatar
Default Re: ~~~ PARTING OUT!!! 500+whp turbo kit, tranny, exedy, aem, garrett, slicks, LOOK! (dunkd)
UP for race
Old Jan 11, 2007 | 04:11 AM
FastAsleep's Avatar
Default Re: ~~~ PARTING OUT!!! 500+whp turbo kit, tranny, exedy, aem, garrett, slicks, LOOK! (ivt-t)
up for good stuff and a good guy
Old Jan 11, 2007 | 05:00 AM
Baggy Spandex's Avatar
Default Re: ~~~ PARTING OUT!!! 500+whp turbo kit, tranny, exedy, aem, garrett, slicks, LOOK! (FastAsleep)
::sigh::
A little piece of me just died inside
Old Jan 11, 2007 | 05:32 AM
ZacCarter's Avatar
Old Jan 11, 2007 | 09:01 AM
RPRacing's Avatar
good luck bud
Old Jan 11, 2007 | 10:42 AM
dunkd's Avatar
thanks guys
Old Jan 11, 2007 | 10:46 AM
Themouse's Avatar
Bump Do you still have all the stuff for sale
Old Jan 11, 2007 | 10:47 AM
dunkd's Avatar
Default Re: ~~~ PARTING OUT!!! 500+whp turbo kit, tranny, exedy, aem, garrett, slicks, LOOK! (Themouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Themouse &raquo;</TD></TR><TR><TD CLASS="quote">Bump Do you still have all the stuff for sale </TD></TR></TABLE>
If anything sells I'll update.. but yah everythings still here.
Old Jan 11, 2007 | 11:11 AM
JohnnysEG's Avatar
Bump for partin out a killer setup!
Old Jan 11, 2007 | 11:22 AM
Mr.OB*GYN_Rhett's Avatar
Default Re: ~~~ PARTING OUT!!! 500+whp turbo kit, tranny, exedy, aem, garrett, slicks, LOOK! (JohnnysEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnysEG &raquo;</TD></TR><TR><TD CLASS="quote">Bump for partin out a killer setup! </TD></TR></TABLE>
hell yeah
Old Jan 11, 2007 | 11:26 AM
codys liquidation sale
Old Jan 11, 2007 | 12:06 PM
Default Re: ~~~ PARTING OUT!!! 500+whp turbo kit, tranny, exedy, aem, garrett, slicks, LOOK! (japspecjohn)
High quality parts from a meticulous dude. Someone put this stuff to good use please
Old Jan 11, 2007 | 12:11 PM
Topher.'s Avatar
Default Re: ~~~ PARTING OUT!!! 500+whp turbo kit, tranny, exedy, aem, garrett, slicks, LOOK! (NAisBEST)
Sad day that your parting out the car, only heard you get on the car once and it scared the **** out of me!!
BUMP for some sick parts
Old Jan 11, 2007 | 12:21 PM
Default Re: ~~~ PARTING OUT!!! 500+whp turbo kit, tranny, exedy, aem, garrett, slicks, LOOK! (B92P_DC2)
i dumped my drawers in the car hahaha
Old Jan 11, 2007 | 01:25 PM
webber17's Avatar
whats the best you can do on the traction bar and exhaust shipped to 53593 e-mail me pics at webber17@hotmail.com thanks,mitch
Old Jan 11, 2007 | 02:39 PM
T T T
