HELP...IT WON'T STAY ON!!!
Old Jan 10, 2007 | 06:17 PM
krytykalintentions's Avatar
Default HELP...IT WON'T STAY ON!!!
i got a 92 integra with a b16 block and a type r head. when i go 2 turn my car on the idle falls rapidly and my car wants 2 shut off. i have 2 hold the gas pedal 4 it 2 stay on. i was told 2 bleed the coolant system which i did and it's still doin it. wat else should i do???
Old Jan 10, 2007 | 06:26 PM
gezzuzz's Avatar
Default Re: HELP...IT WON'T STAY ON!!! (krytykalintentions)
create a vacuum leak by pulling of your the vacmuun hose off the fuel pressure regulator.. and see if it will keep a idle..
sounds like your IACV
i just told this to someone else
"clean your iacv out with some throttle body cleaner."
you sould do it too..
Old Jan 10, 2007 | 07:44 PM
Default Re: HELP...IT WON'T STAY ON!!! (gezzuzz)
thanks ill try it out and get back 2 ya
Old Jan 10, 2007 | 07:48 PM
DrewMD's Avatar
Davis Photography
could you need to adjust your throttle?
Concept14
Jan 5, 2010 07:38 PM
92egSnatch
19
Feb 20, 2008 02:19 PM
neldogg
Nov 17, 2007 03:52 PM
krytykalintentions
Jan 10, 2007 07:32 PM
ATS*Mark
12
Dec 22, 2005 07:14 PM
