What bearings to use?????
Old Jan 10, 2007 | 05:56 PM
crxking1's Avatar
Default What bearings to use?????
Hey guys, I'm building a B16a engine. I need advice on what main and rod bearings to use. My builder insists I use OEM colour coded bearings. I've been reading alot in the forum and see alot of guys using ACL bearings. What is my best choice?
Old Jan 10, 2007 | 06:09 PM
doood's Avatar
been there done that
Default Re: What bearings to use????? (AntiguaCrx)
whichever one's that give you the desired clearances
Old Jan 10, 2007 | 06:24 PM
Runnerdown's Avatar
you can never go wrong with the oem bearings on that motor (properly clearanced of course )
Old Jan 10, 2007 | 07:47 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AntiguaCrx &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, I'm building a B16a engine. I need advice on what main and rod bearings to use. My builder insists I use OEM colour coded bearings. I've been reading alot in the forum and see alot of guys using ACL bearings. What is my best choice? </TD></TR></TABLE>
your builder is correct listen to him i have found in personal experience that the oem ones will guarantee you have the best tolerances
as for ACL lol no thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">you can never go wrong with the oem bearings on that motor (properly clearance of course )</TD></TR></TABLE>
or any honda motor for that matter in my opinion!
Old Jan 10, 2007 | 08:27 PM
smileycvc's Avatar
Default Re: What bearings to use????? (richard7968)
If the clearances are good go OEM only goto ACL as backup
Old Jan 11, 2007 | 01:09 AM
91SiZ6's Avatar
Your builder wants to use OEM so he can get the exact clearance he wants without unnecessary machining.
Old Jan 11, 2007 | 05:06 AM
LSVTEC 91 Civic's Avatar
Banned
If they clearance out properly it's no big deal. I've used ACL, and now Clevite.
Old Jan 11, 2007 | 06:31 AM
2001B18C1GS-R's Avatar
im running acl regular not problems if your clearance them out well enough you'll have no problems
Old Jan 11, 2007 | 11:48 AM
ExospeedAMcrx's Avatar
OEM bearings is what we use. With the different color coded sizes, you can get PRECISE measurements to get EXACT clearances on each single bearing. The only way you can get that with ACL is if you're lucky that they all fall into EXACT clearances or if you take out material out of the crank journals/rods to make the ACLs exact to each one.
Old Jan 11, 2007 | 11:52 AM
Combustion Contraption's Avatar
They dont use ACL in NASCAR
Old Jan 11, 2007 | 12:17 PM
91SiZ6's Avatar
Default Re: What bearings to use????? (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">Your builder wants to use OEM so he can get the exact clearance he wants without unnecessary machining.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">OEM bearings is what we use. With the different color coded sizes, you can get PRECISE measurements to get EXACT clearances on each single bearing. The only way you can get that with ACL is if you're lucky that they all fall into EXACT clearances or if you take out material out of the crank journals/rods to make the ACLs exact to each one.</TD></TR></TABLE>
Old Jan 11, 2007 | 12:33 PM
zCivic's Avatar
Default Re: What bearings to use????? (91SiZ6)
I've used ACL in 3 builds. Never had a clearance issue, except one time which was machine shops fault for not telling crank had to be taken down so would need larger bearings for mains.
Old Jan 11, 2007 | 12:58 PM
91SiZ6's Avatar
Default Re: What bearings to use????? (zCivic)
A "clearance issue" and exact clearances are two different things.
Old Jan 11, 2007 | 02:30 PM
Cutting the crank is the LAST resort in getting the right clearances for us. Its nice to have different sizes with OEM bearings to make your adjustments in your measurements and not rely on having to cut cranks.
Old Jan 11, 2007 | 03:18 PM
zCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">A "clearance issue" and exact clearances are two different things. </TD></TR></TABLE>
Clearance issues I would consider out of spec, same thing to me. If within clearances rock use them, if out of clearance dont.
The crank was turn for other reasons then bearing clearances. This was a few years ago and I believe the crank was scared so they took it down.
Old Jan 11, 2007 | 03:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">
the crank was scared so they took it down.</TD></TR></TABLE>
I was trying to figure out for a sec there how the crank got SCARED? hehe. j/k
Well thats the difference between certain builders.
Some like to fall "within" clearance specs.
Others like to be more Exact.
If you are paying for a build, wouldnt you like it to be more precise, rather than something falling within whats a desired range.
umair
Mar 23, 2011 08:13 PM
Mhollaek9
Sep 1, 2007 03:06 PM
crxking1
Jan 14, 2007 06:57 PM
vtec-gorilla
Aug 14, 2006 10:45 PM
b16 matt
Apr 26, 2005 12:17 AM
