Accord 02 DX f23a5 help
Old Jan 10, 2007 | 05:34 PM
Honda mota's Avatar
Default Accord 02 DX engine performance question
I have been told i cant do much with my f23a5 because it cant handle the power. I have an intake and header. I want to know if this is true in the first spot. And second if this is true can i change the head on this engine?
Thanks,
Modified by Honda mota at 6:59 PM 1/10/2007
Old Jan 10, 2007 | 07:05 PM
iam7head's Avatar
Default Re: Accord 02 DX engine performance question (Honda mota)
Pretty much true if you going NA route, same goes for Vtec F's
Old Jan 11, 2007 | 04:59 AM
TouringAccord's Avatar
H-T Order of Merit
yes, you can change the head on you engine. The work involved could be a lot but that depends.
Take a look at the Accord FAQ which is stickied at the top. Scroll down to Swaps and you'll see a few links to head swaps. Those should answer your questions and give you a good idea of what would be involved.
Old Jan 11, 2007 | 07:49 PM
jweller's Avatar
Default Re: Accord 02 DX engine performance question (TouringAccord)
the a5 will handle a 75 shot of N2O like a champ.
the VTEC head will swap right on. actually, it's simpler than that. you really just need to swap the cam and rockers. the castings are the same. you'll still need to source a vtec solenoid, ecu, and distributor, but it's pretty straight forward. you still won't have the same power levels as the a1/a4 because the a5 has lower compression pistons, but it should give you some extra go.
Johnst185
Apr 25, 2010 02:36 PM
XLR8_HFX
Dec 4, 2005 08:05 AM
gduprice
Aug 23, 2004 03:40 AM
89dxhunchback
Dec 31, 2003 11:51 AM
nostalgia
Apr 8, 2003 02:37 PM
