Hesitation Issue...
So I buy my 2K from a dealer here in town for a pretty reasonable price, and I was pretty sure I was set.
It has the clutch buzz, and I'm okay with it.
It needed the taillamps replaced...done buy honda the next week.
All other recalls done previously.
Car has 40,302 at the time of purchase.
It waits a couple of weeks, and then when I'm pulling into traffic, I got this wierd hicup of a response under 2500rpm. It was like the power was on-off-on-off-on. Kinda like it wasn't getting enough fuel. It's done it a couple times since then, but not frequently.(I've put nearly 2k on it since I bought it.)
I have all kinds of records with it, so I figured it had to be well maintained, and the car itself was nearly mint when I bought it.(With the exception of the front tires needing to be replaced.)
Is this a common issue, or do I need to start searching through all these reciepts from past Honda dealers looking for a fuel filter replacement? Keep in mind, it's not a normal problem, just happened 3 times over a 6 week period.
From: A place where stupidity runs rampant aka NorCal
Mine does the same thing in traffic, ive heard its a issue with the map sensor, you might want to run a search on map sensor or what some people refer to as "the map sensor whack"
-Todd
-Todd
This issue you're describing I think I have the same problem too w/ my S2K. My car has 18,XXX miles on it. "Count Blah" mentioned it having something to do w/ the MAP sensor, I've heard the same things from S2Ki as well. Actually they have a sticky in one of their threads that talks about this issue, so I believe its not uncommon.
I get the 'hicup" in first when I try to drive it in that gear under 3k rpms. I don't believe it's unusual. I just don't drive it in first under 3k rpm's anymore!
Buy a new MAP sensor from honda, they come with a zip-tie type thing now that wraps around the plug to hold it in place.
Although you could probably just put a zip tie on yourself but I think OEM looks better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntensehonda »</TD></TR><TR><TD CLASS="quote">ok...I need details
Can it be fixed?</TD></TR></TABLE>
Locate MAP sensor. Remove the 2 screws. Use the handle of the screw driver and tap the top of the sensor a few times, firm but not too hard. Remove MAP sensor. Use an airspray can or pipe cleaner to remove any debris from the pinhole that the sensor works off of. Once clean, replace sensor and zip tie the harness plug to the sensor, it tends to vibrate loose.
i need to do this, got of picture?
to OP: its normal for my car to kinda of "hicup" or have a slight bog if im driving under 2k, it just wants you to rev the **** i guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 »</TD></TR><TR><TD CLASS="quote">i need to do this, got of picture?
to OP: its normal for my car to kinda of "hicup" or have a slight bog if im driving under 2k, it just wants you to rev the **** i guess.</TD></TR></TABLE>
It's the sensor on top of the TB.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL »</TD></TR><TR><TD CLASS="quote">This is in 1st while taking off slowly in traffic correct? I have experienced this as well [in a friends car] and I was wondering what it was.</TD></TR></TABLE>
haha this happens to me all the time... (2000 ap1 with 25k) i figured i just had an unstable foot and once it starts bouncing i cant stop it unless i hit the clutch or slam on the gas... sounds like the same problem, but it might just be that im retarded as previously speculated by yours truly. im blooowwwnnn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt »</TD></TR><TR><TD CLASS="quote">
It's the sensor on top of the TB. </TD></TR></TABLE>
i know what a map sensor is, but is there a correct way to zip tie it, or is there only one way, i haven't checked it out,
This should give you all the info you need...
Intermittent Hesitation During Hard Acceleration
Official Honda TSB
Official Honda TSB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 »</TD></TR><TR><TD CLASS="quote">This should give you all the info you need...
Official Honda TSB</TD></TR></TABLE>
ive never had the problem in high RPM's... as a matter of fact actually ive never had the problem above 1800-2000 rpms..
EF2SLOW
May 3, 2012 01:34 AM
