Where Can I Get The Gasket/O-Ring Around Injectors
Old Jan 10, 2007 | 03:54 PM
roterx7's Avatar
Default Where Can I Get The Gasket/O-Ring Around Injectors
i need some new gasket/o-rings around my injectors, can stand to see gasket maker around it. where can i get some or order some for cheap? 89 crx si w/ sohc zc
thanks
Old Jan 10, 2007 | 07:10 PM
haroldthefly91crx's Avatar
Default Re: Where Can I Get The Gasket/O-Ring Around Injectors (roterx7)
same problem, i took an injector to one of my local auto parts stroes and they had a box full of o-rings and **** and it worked out great and just to make sure it sealed i used some sylicone
Old Jan 10, 2007 | 07:13 PM
eda6's Avatar
Default Re: Where Can I Get The Gasket/O-Ring Around Injectors (haroldthefly91crx)
cheapest route is the junkyard. make sure you dip them in oil before installing.
Old Jan 10, 2007 | 07:29 PM
sohcvtec91hatch's Avatar
Default Re: Where Can I Get The Gasket/O-Ring Around Injectors (eda6)
Any auto parts store, But it's not cheap like 10 bucks an injector atleast. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote"> make sure you dip them in oil before installing.
Old Jan 10, 2007 | 07:42 PM
Crx Jimmy's Avatar
Default Re: Where Can I Get The Gasket/O-Ring Around Injectors (sohcvtec91hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec91hatch &raquo;</TD></TR><TR><TD CLASS="quote">Any auto parts store, But it's not cheap like 10 bucks an injector at least. </TD></TR></TABLE>
what? 10 bucks an injector for a o-ring you can get a box of them for that price! just buy them from honda they are like a couple bucks if that, and dont use any kind of silicone anywhere near the fuel system. the fuel rapidly decomposes silicone and turns it gummy and if that gets in the fuel system have some real fun trying to ever get it all out
Old Jan 10, 2007 | 08:20 PM
jdm_ef9_b16's Avatar
why not go to honda?
Old Jan 10, 2007 | 08:52 PM
s10cky's Avatar
I paid like 45 bucks after tax for all the new 0-rings. It was worth it though.
Old Jan 10, 2007 | 10:54 PM
1 Fly SI's Avatar
Default Re: (s10cky)
get a assortment of o-rings from the auto parts store. T<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
what? 10 bucks an injector for a o-ring you can get a box of them for that price! just buy them from honda they are like a couple bucks if that, and dont use any kind of silicone anywhere near the fuel system. the fuel rapidly decomposes silicone and turns it gummy and if that gets in the fuel system have some real fun trying to ever get it all out </TD></TR></TABLE>here are some in there that fit.
Old Jan 11, 2007 | 07:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10cky &raquo;</TD></TR><TR><TD CLASS="quote">I paid like 45 bucks after tax for all the new 0-rings. It was worth it though.</TD></TR></TABLE>
See that's what I'm talkin about. I'm sure you could go to home depot and put any o ring on there, but i'm talkin aobut the actual replacement parts.
Old Jan 11, 2007 | 07:15 AM
crx_si-r's Avatar
Default Re: (sohcvtec91hatch)
yea i work at a CSK (Checker, Shucks, Kragen auto parts depends where u live) n i bought the beck n arnley injector seal kit comes with 3 orings and the seal that goes inside the intake manifold for $8each
Old Jan 11, 2007 | 07:41 AM
DaX's Avatar
DaX
Loved
Community Favorite
Injector seals are about $7 ea from the dealership.
Old Jan 11, 2007 | 10:31 AM
thesmogman's Avatar
Default Re: (DaX)
I just got delivered the set for all four from the dealer. $35 bucks
There are three seal's per injector. And only one is an O-ring.
Here are the P/N#'s
#91301-PM7-003 O-ring
#16473-P10-A01
#16472-P10-A01
There you go.
Old Jan 11, 2007 | 10:34 AM
fireant's Avatar
Default Re: (thesmogman)
You shouldn't need to replace the expensive "cushions". The tiny injector o-rings themselves add up to like $10 or so for all four at Honda.
Old Jan 11, 2007 | 11:15 AM
thesmogman's Avatar
Default Re: (fireant)
Shouldn't..... Well I believe that if you are there already, might as well. Also the ones that are in there are 19 years old.
PS: look below.
Old Jan 11, 2007 | 12:51 PM
CrXThang's Avatar
I got mine at this place called Quality Auto. A kit for each injector is 6 bucks. Heres the number 17148906687
Old Jan 11, 2007 | 01:02 PM
1QuikSOHCZC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">cheapest route is the junkyard. make sure you dip them in oil before installing.
wow i got mine from honda. i would never get anything like that from a junkyard
Old Jan 11, 2007 | 01:38 PM
Fezzie's Avatar
honda dealership
Old Jan 11, 2007 | 02:14 PM
Default Re: (crx_si-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_si-r &raquo;</TD></TR><TR><TD CLASS="quote">yea i work at a CSK (Checker, Shucks, Kragen auto parts depends where u live) n i bought the beck n arnley injector seal kit comes with 3 orings and the seal that goes inside the intake manifold for $8each</TD></TR></TABLE> That's a discounted price i'm sure! Anyways just buy the kit, or whatever you think will work if it works out using the o-ring off of your old weed pipe then it works. The best bet is a replacement part.
Old Jan 11, 2007 | 02:23 PM
fireant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">You shouldn't need to replace the expensive "cushions". The tiny injector o-rings themselves add up to like $10 or so for all four at Honda.</TD></TR></TABLE>
LOL, I must confess I did pay $50 to replace all mine too, but after seeing it all apart, the o-rings were crumbling trash, while the cushions looked like the new ones I'd already bought.
TIP: Old injector cushions fit perfectly onto the gearshift shaft to support a sagging shift boot.
Old Jan 11, 2007 | 03:03 PM
roterx7's Avatar
thats what i was afriad of, very pricey for 4 rubber o-rings for my injectors. Quality Auto, is there a website for them?
Old Jan 11, 2007 | 05:52 PM
Default Re: (roterx7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roterx7 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i was afriad of, very pricey for 4 rubber o-rings for my injectors. Quality Auto, is there a website for them?</TD></TR></TABLE> There are actually 12 o-rings to repace 3 per injector, If you do all of them.
Old Jan 11, 2007 | 05:59 PM
e jay one's Avatar
maybe its different in other states but for the 4 o rings the only ones you should need to replace were a dollar something each at the dealership no parts store had them check out http://www.hondaautomotiveparts.com there o ring sizes on there i couldnt find those sizes anywere but the dealership.
Old Jan 11, 2007 | 06:22 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QuikSOHCZC &raquo;</TD></TR><TR><TD CLASS="quote">
wow </TD></TR></TABLE>
i know. instead of spending over $40, making two trips to honda and having a week of downtime, i got the IM to injectors cushions for $1 from the junkyard, then went to home depot and spent $1 on o-rings.
saved myself $38 and had the car up and running in two hrs.
Old Jan 11, 2007 | 09:10 PM
bought mine from the honda Dealership in my city. the same day i went. took me 10 mins to get there and buy them(yes they had them!). PLUS my cuzin works in the parts department. so i only had to pay 17.88 for gaskets/o-rings for all 4 of my injectors..........id rather have honda o-rings then home depot hahaha
took me 45 mins. thats it. and i saved money too but i have O.E.M goodness
Old Jan 12, 2007 | 04:24 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">TIP: Old injector cushions fit perfectly onto the gearshift shaft to support a sagging shift boot. </TD></TR></TABLE>
Nice tip!
