JDM D15b wiring information
A freind of mine is swaaping a JDM D15b into his 95 Civic. i wass wanding if anyone had the wiring diagrams or what needs to be done to get this thing running. He has the stock ecu. Does he need to get another harness and ecu from a jdm car. Anyhelp would be appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OzzManG149 »</TD></TR><TR><TD CLASS="quote">A freind of mine is swaaping a JDM D15b into his 95 Civic. i wass wanding if anyone had the wiring diagrams or what needs to be done to get this thing running. He has the stock ecu. Does he need to get another harness and ecu from a jdm car. Anyhelp would be appreciated.</TD></TR></TABLE>
No, everything will plug right up. Assuming the car is a Si or EX (VTEC models). If not he'll have to wire in VTEC (2 wires). Aside from that everything will plug right up into his existing harness
The ECU needs to be the P08 ECU for the JDM D15b.
.The ECU needs to be the P08 ECU for the JDM D15b.
Syndacate
I greatly appreciate the information. Im pretty ure its the none V-tech do you know where I might find the wiring info for that?
https://honda-tech.com/zerothread?id=724252
Wiring VTEC. The hardest thing is to find new pins and route the wiring through the firewall.
jasonvictory86
Apr 30, 2020 07:35 PM
EF4lyfe
Jul 30, 2004 04:47 AM
