Clutch Master Cylinder?
Well, it looks like my clutch master cylinder is out on my 92 S.
I got in to go to work the other day and it went straight down to the floor, no resistance. I guess I'll try bleeding it first but I'd bet since it went out immediately like that, its a broken master cylinder.
Here's my question. Has anybody replaced this before? I've never done it and I'm wondering how much time I should plan on taking to do it.
Thanks!!!
Thanks!!!
shouldnt take too long the bolts coming out of the master cylinder go through the clutch pedal and bolt on the actual pedal, kind of a pain to get the one nut on and off but other than that its pretty straigth forward
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by osiris1741 »</TD></TR><TR><TD CLASS="quote">I would but money is a serious hangup right now. I guess another 30 bux would be worth the hassle of doing it all over again though.
Trust me, it's better do it them both at once now than to have to do the work all over again later.
if you do it for the first time, set aside a few hours
if you've done it before, it only takes like 30 mins
its fast if you already know where everything is and what you're doing.
also remember to bleed the clutch fluid PROPERLYYYY
Well I got all my parts but I cant get the damn pin out. Its almost inaccessible. The pin is pressed right up against the outside of the pedal and there isn't enough room to get any of my tools in between the pedal and the side wall.
Any ideas?
Any ideas?
if the clutch MC is at fault u should see clutch fluid leaking and dripping around it. The only reasy the clutch pedal goes straight to the floor is because of the lack of pressure. So go through and try and see if u can find where the leak is, all the way from the clutch MC through the clutch line to the clutch SC.
siregcivic
Oct 16, 2005 07:55 PM
RiCE On IcE 2
Mar 6, 2003 03:47 PM
