86 Accord how to help plz
Hello everyone , im in need of help my accord is my first honda and i dont know how to change the belts becuz the motor is side ways im new to hondas being my first honda plz help me thank you
86 accord lxi
greddy exhaust
glow wires
toyos
homemade radiator
86 accord lxi
greddy exhaust
glow wires
toyos
homemade radiator
loosen the top and bottom bolt of the P/S pump it will swivel and you remove the belt.
Loosen the top and bottom bolt of the ALT, then under the brake master cylinder there is a 12mm nut on a long threaded rod that goes to the top bolt of the alt, that releases the tension.
The A/C belt tensions differently depending on the type of compressor but you might be able to figure out the top and bottom bolts need to be loosened [ both sides of the compressor] and then there is a threaded long bolt to use for tensioning. From the front of the subframe for kehien compressor and from under the compressor for the ND compressor.
1mcpherson
Jun 29, 2010 03:24 PM
