Top Speed limit removal EP3
Old Jan 10, 2007 | 11:48 AM
darthure's Avatar
Default Top Speed limit removal EP3
Does anyone know how to get rid of that nasty 110mph limit that the stock ECU has. Or atleast make it higher without changing the stock ECU.
Old Jan 10, 2007 | 12:37 PM
B18CXr's Avatar
Default Re: Top Speed limit removal EP3 (dae_elliott)
there is no speed limiter.........
Old Jan 10, 2007 | 01:36 PM
HAMB0NE's Avatar
Default Re: Top Speed limit removal EP3 (B18CXr)
Old Jan 10, 2007 | 04:33 PM
darthure's Avatar
Hmm. I am not sure but when i hit 110mph the motor seems to cut out until i fall below that speed. I just got this SI so i don't know that much about it. What would you call the motor cutting out then?
Modified by darthure at 7:31 PM 1/10/2007
Old Jan 10, 2007 | 05:19 PM
cbmprelude's Avatar
* B A N N E D *
op your a dumb *** and should lose your license
Old Jan 10, 2007 | 05:32 PM
darthure's Avatar
Default Re: Top Speed limit removal EP3 (cbmprelude)
I guess you have nothing constructive to add to this thread.
Old Jan 10, 2007 | 06:15 PM
Andrey's Avatar
JDM k20a and JDM CTR are limited to 180kmh or 110mph do u have one?
Old Jan 10, 2007 | 06:19 PM
darthure's Avatar
Default Re: (Andrey)
I have a stock 02 civic SI. I beleive the motor is a K20A3.
Old Jan 10, 2007 | 06:41 PM
fEPst3r's Avatar
maybe u got a cool ep with a retarded ecu? i havent heard anyone else with this problem on their stock ep
Old Jan 10, 2007 | 07:16 PM
Rice-aronie's Avatar
Default Re: (fEPst3r)
maybe ur ecu is not stock? Someone did a kpro on the original ecu then swapped whatever they could get their hands on to put back in the car?
Old Jan 10, 2007 | 10:09 PM
C4st0r_Tr0y's Avatar
Official H-T Cake Maker
Default Re: (Rice-aronie)
yah there is no speed limit, or goveneror i mean
ive hit at least 120--once hehe
Old Jan 11, 2007 | 03:28 PM
darthure's Avatar
Thanks, i had no clue about that. I guess it is possible that the previous owner changed the ECU. I am not sure if you know this one. What RPM does the IVTEC kick for the JDM CTR or JDM K20a?
Old Jan 11, 2007 | 07:44 PM
Nataku's Avatar
Default Re: Top Speed limit removal EP3 (darthure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darthure &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know how to get rid of that nasty 110mph limit that the stock ECU has. Or atleast make it higher without changing the stock ECU.</TD></TR></TABLE>
This message is to inform you that you have been nominated for the 2007 Honda-Tech Darwin Awards! Please place "Honda-Tech Darwin Award Nominee - 2007" in your sig to help spread awareness.
Old Jan 11, 2007 | 10:01 PM
Andrey's Avatar
Default Re: (darthure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darthure &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, i had no clue about that. I guess it is possible that the previous owner changed the ECU. I am not sure if you know this one. What RPM does the IVTEC kick for the JDM CTR or JDM K20a? </TD></TR></TABLE>
6k i think and 2.2k for us which u dont feel at all cause it just becomes 16 valve after 2.2k
Old Jan 12, 2007 | 02:23 AM
darthure's Avatar
Hmm. I am pretty sure i have the JDM ECU because my ivtec kicks in around 6k -6.2k . And when it kicks in it definitely feels like i pushed a NOS button or something. The only thing that sucks about having this ECU is the governor. Any thoughts on how to get rid of it? I know reflash is one option. I was actually considering changing the entire ECU because of this governor issue.
Old Jan 12, 2007 | 05:38 AM
Kal's Avatar
Kal
k20a3 does not have the three lobe VTEC.
Since you stated in this thread that you have a STOCK 02 Si, it is highly unlikely you have anything you're describing.
The only speed governor is gearing and power.
Old Jan 12, 2007 | 11:17 AM
GradyDC5's Avatar
Cuttting out would be you reaching 110 then the motor revving down to 105 or so then going back up to 110.. Something like GM vehicles do.
You are most likely in too high of a gear, with too little power, and wind resistence.
Old Jan 12, 2007 | 01:34 PM
...me0w's Avatar
my stock 02 ep will do 140 then wind resistance kills it dont ask me how i know just know..................
Old Jan 12, 2007 | 03:36 PM
HAMB0NE's Avatar
Default Re: (...me0w)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nataku &raquo;</TD></TR><TR><TD CLASS="quote">
This message is to inform you that you have been nominated for the 2007 Honda-Tech Darwin Awards! Please place "Honda-Tech Darwin Award Nominee - 2007" in your sig to help spread awareness.</TD></TR></TABLE>
Bahahahahahaha
Old Jan 12, 2007 | 06:15 PM
darthure's Avatar
Default Re: (Kal)
Umm. I bought the car from a dealer so i assumed that the engine was stock. The Vtec definitely kicks in at around 6k-6.2k RPM it is very obvious and it definitely cuts out at around 110MPH. I just tried it again today on the way home just to make i wasn't going crazy. I have been asking around and all the symptoms point to a possible ECU swap. The motor is definitely a K20A3. However i cannot rule out the possibility that the internals might have been upgraded. The car is pretty quick.
Anyway, i kind of went off track for a second. Back to my original question. How do i get rid of the nasty 110MPH limit without changing the ECU. Or would i need to get an entirely new ECU?
Old Jan 12, 2007 | 08:19 PM
DC5StylZ's Avatar
ur on dope....
Old Jan 12, 2007 | 08:45 PM
BarracksSi's Avatar
What's the rev limiter set at? I know the redline on the tach should be about 6800 rpm, but how high does the motor rev?
Old Jan 13, 2007 | 03:39 AM
darthure's Avatar
Default Re: (BarracksSi)
Idling the limiter is at 6k. Moving i have gone up to 7.5k no problem.
Old Jan 13, 2007 | 12:06 PM
DC5StylZ's Avatar
only dope's do dope uu ******* druggie moron sell ur car and buy a kia u wont have to think as much
Old Jan 13, 2007 | 12:17 PM
darthure's Avatar
Default Re: (DC5StylZ)
Hahaha. Relax, it is not that serious. Calm down before you hurt yourself. Not everyone is as wise as you when it come to cars. If i wanted a Kia i'd probably come directly to you for advice. Thanks for your input though.
