89 prelude help....Please b20a5
hey everyone i just got a 89 prelude si... with the b20a5 motor in it...2.0
is there any parts i can do with this and can i build the block up and throw a vtec head on it ? what all do i need and any info will help thanks everyone
This will be your best and only engine swap option.
88-91 H22 Swap Info : https://honda-tech.com/zerothread/1860111
As for Turbo Chargining this info will be your best resource:
http://www.preludepower.com/fo...36790
Sean
Sean
I am sorry I forgot to mention that there was a B16, B18 swap done on this generation of car, but the engine was too tall and you will not be able to drop the car due to the height of the engine.
As far as swapping the B16 head or B18 head on the the B20A5 block, it was done but with not success, too much custom work to make it work and the trying to work the bugs out was impossible.
Just stick with Turbo Charging or H22 swap.
Sean
Sean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax »</TD></TR><TR><TD CLASS="quote">No one ever thinks of the JDM B20A. It's not great, but it's better than a USDM B20Ax</TD></TR></TABLE>
JDM B20A is fine if you just want to replace a dead motor. JDM B20A swap is pointless as it will only yield a couple more hp (if that). And aftermarket support for that motor is not that great.
B20A's are also decent for turbo build-up's but after all is said and done the H22A swap will make the car just as fast, more reliable, and you'll have plenty of aftermarket parts to choose from. H22A swap FTW.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch92only »</TD></TR><TR><TD CLASS="quote">So.... can i build the block and have head completly redone and throw a new turbo on there ? like is there aftermarkey pistons and rods and head internals ?</TD></TR></TABLE>
That would end-up costing you a lot more than what you would pay for the H22 swap.
I'd rather go with the H22 and some bolt-on's.
Anything is possible, but it all depends on how many pesos you're willing to spend and what you plan to use the car for.
Yes there is aftermarket pistons and rods. We use the same brand as any other Bseries motors you just have to have them made specifically for the B20A5 motor and not he B20A accord motor.
There are some differences so you will need to make that clear when ordering a set from the manufacture or retail shop you are getting them from.
Sean
Sean
do u know any good sites that sell the b20a parts ? h22a looks a lil hard and complated and $...... and the engine has like 212k miles on it right now so i would love to have the built up...... but havent seen too many b20a's
No. The B20B engine will not fit properly, there is a guy in europe who made it go in but he is still trying to make it work.
Here is the info on that swap:
Here is the link to that specific thread:
http://www.preludepower.com/fo...51087
B20B in the works
Due to hood clearance he tilted the engine foward. I see this as a problem down the road but for all 3rd gens sake I hope it works out.
Sean
B20B in the works
Sean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch92only »</TD></TR><TR><TD CLASS="quote">AND would a b20b block go into the prelude to replace the b20a ?????</TD></TR></TABLE>
No.
I've had a 3rd gen and gave up on the B20A5... You'd have to spend an arm and a leg to get some decent power out of it. I wouldn't mess with that motor ever again, and that's my honest opinion. It's just not worth the money, the time, the sweat...
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GtechPro »</TD></TR><TR><TD CLASS="quote">
No.
Oh come on...
This engine has alot of potential once boosted. It comes stock with iron sleeves, which means you dont have to sleeve the block, just reinforce all the other internals depending on the amount of boost you want to run.
Alot of us owners of the 3rd gen know that it does take money, time and effort to make this car the way it should be, but that is what makes it so special after all is said and done.
No trying to put down other Honda owners, but this car is well worth the the effort once she has been rebuilt and upgraded.
Sean
No.
Oh come on...
This engine has alot of potential once boosted. It comes stock with iron sleeves, which means you dont have to sleeve the block, just reinforce all the other internals depending on the amount of boost you want to run.Alot of us owners of the 3rd gen know that it does take money, time and effort to make this car the way it should be, but that is what makes it so special after all is said and done.
Sean
b20b in a prelude in running condition: http://www.cardomain.com/ride/2236093/4
Just thought I'd put it out there
there is a ton of aftermarket support for a b20a5 motor....you just have to look in the rite places....
it's all about what kind of hp you looking for and if you want a reliable car.
do you want a turbo tuned car?
or a all motor tuned car?\
chioce is yours.
chioce is yours.
just picked up the b20b block from dannie just waiting for it to get here!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch92only »</TD></TR><TR><TD CLASS="quote">i think im gna just drive it unitl it blows... </TD></TR></TABLE>
