99 si wing brake light wiring...
there is a wire coming from the brake light in the wing but it doesn't plug into the third brake light wire from the brake light in the back window. is there some kind of wiring harness i need??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicksiguy »</TD></TR><TR><TD CLASS="quote">there is a wire coming from the brake light in the wing but it doesn't plug into the third brake light wire from the brake light in the back window. is there some kind of wiring harness i need??</TD></TR></TABLE>
If this is the OEM accessory wing, it does indeed plug in near the third brake light. It's been a while, so I don't recall if there is a separate plug, but I believe there is. It may just be tucked out of sight.
alright so there are three wires coming from the brake light wiring above the trunk: 2 green/white and 1 black. there are two wires coming from the brake light in the wing: 1 black and 1 green/white. how do i splice these?
