91Si motor in to a HF
Old Jan 10, 2007 | 10:25 AM
HFpower's Avatar
Default 91Si motor in to a HF
is there any difrence or is it stright plug and play
Old Jan 10, 2007 | 10:52 AM
badnewz's Avatar
Should be straight plub and play. Both the SI and HF have 4 injectors with resistor boxes as oppsed to the DX. You plan on swappin the tranny for the SI too?
Old Jan 10, 2007 | 10:53 AM
HFpower's Avatar
Default Re: (badnewz)
yea whole complete swap
Old Jan 10, 2007 | 11:27 AM
ChickenH's Avatar
Default Re: (HFpower)
put the SI ecu and injectors in it you will notice a diffrence. i think i have a couple of 89 si ecus if you cant find one locally. besides thaat its pretty much plug and play. the wheel hubs on some HF are diffrent ( smaller axle hole?) and you have to use the HF axles.
Old Jan 10, 2007 | 11:33 AM
Tippyman's Avatar
Default Re: (ChickenH)
It's a direct swap if you use the Si tranny, Si engine, Si computer, and HF axles.
Old Jan 10, 2007 | 11:40 AM
jlicrx's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">It's a direct swap if you use the Si tranny, Si engine, Si computer, and HF axles.</TD></TR></TABLE>and HF engine wiring harness
Old Jan 10, 2007 | 11:41 AM
Tippyman's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">and HF engine wiring harness</TD></TR></TABLE>
Well yeah, I thought that was obvious.
xparalandrax
18
Mar 10, 2007 10:57 AM
spunautosports
10
Oct 28, 2006 10:08 AM
fullraceacura
May 24, 2005 09:49 AM
pdiddyparsons
Feb 18, 2003 11:34 AM
hybridcrx
11
May 27, 2002 05:06 PM
