b18 head on as b16A2 block?
Old Jan 10, 2007 | 10:08 AM
rdwaldo's Avatar
Default b18 head on as b16A2 block?
I am about to get a port and polish done on my head soon. I have a b16a2 but im wondering if i can get a gsr head or a type r head and if it would mount? i know the heads on those are better than the b16, but i dont know if it will be worth it and if its possible?
Old Jan 10, 2007 | 10:14 AM
jay_cue's Avatar
Default Re: b18 head on as b16A2 block? (rdwaldo)
the type r head is pretty much a b16 head with a factory port. so if you're already going to have the b16 head PP then it would be worthless
Old Jan 10, 2007 | 10:25 AM
oneforce's Avatar
b16 head actually flows better than the gsr head. Save your money and port your head and add some cams, springs, retainers, header. my .02
Old Jan 10, 2007 | 10:34 AM
88rexA6's Avatar
Default Re: b18 head on as b16A2 block? (oneforce)
the only thing better about the gsr head is that it has smaller combustion chambers. but, it'd be better to bump up compression with higher-domed pistons and have the better-flowing head. +1 for porting the b16 head. good luck
Old Jan 10, 2007 | 10:43 AM
gezzuzz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdwaldo &raquo;</TD></TR><TR><TD CLASS="quote">I am about to get a port and polish done on my head soon. I have a b16a2 but im wondering if i can get a gsr head or a type r head and if it would mount? i know the heads on those are better than the b16, but i dont know if it will be worth it and if its possible?
when getting a PP the b16 and type r are the same both better then gsr.
you can get type r cams for your b16a
Old Jan 10, 2007 | 11:53 AM
doood's Avatar
been there done that
tell me again why a b16 head is better than a gsr head?
Old Jan 10, 2007 | 03:47 PM
rdwaldo's Avatar
Default Re: b18 head on as b16A2 block? (doood)
alright point taken, ill PP the b16 head as well as springs, retainers, valvetrain, the works. Im thinking skunk 2 cams and not sure what cam gears yet
rdwaldo
15
Jan 17, 2007 07:03 PM
latinf86
Aug 12, 2006 09:47 PM
hialeahzbg
16
Aug 1, 2006 10:57 PM
B18CRMiKE
Aug 21, 2005 01:52 PM
0bLiViOuS
Jun 17, 2005 01:10 PM
