Changing dizzy for OBD purposes
Old Jan 10, 2007 | 09:38 AM
Syndacate's Avatar
Default Changing dizzy for OBD purposes
Hey, when changing an OBD-II dizzy onto an OBD-I engine b/c you have an OBD-II harness and don't wanna do any wiring alterations, how much do you have to take out. Just the bolts that hold the dizzy on, pull it off, and replace the O ring b4 putting the new one on? Also, how important is it if you don't replace that O ring, will it spring a serious oil leak?
Also, is it possible to re-pin/re-wire the plug w/ a plug from an OBD-I junkyard harness to fit, or does it HAVE TO use that harness? If so, anybody know where I can snag a wiring diagram?
Old Jan 10, 2007 | 09:43 AM
gezzuzz's Avatar
Default Re: Changing dizzy for OBD purposes (Syndacate)
yes only 3 screws hold on the dizzy.. and for repining some of the wires on one of them are thicker.. if you can get you and on the obd-2 do it.. if you find a obd-1 one just splice the obd-2 connectors on it..
replace o-ring but is so easy to take off the dizzy you can do it anytime..
get a honda o-ring
Old Jan 10, 2007 | 09:48 AM
Syndacate's Avatar
Default Re: Changing dizzy for OBD purposes (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">yes only 3 screws hold on the dizzy.. and for repining some of the wires on one of them are thicker.. if you can get you and on the obd-2 do it.. if you find a obd-1 one just splice the obd-2 connectors on it..
get a honda o-ring</TD></TR></TABLE>
Well the engine coming out is OBD-II so I can just pull the dizzy off that. Guess I will, just didn't want to deal with the O ring leaking. I guess I'll just compare the O rings fro the 2 engines and see which one is in better condition and use that one until I can get a new one on there?
Old Jan 10, 2007 | 09:54 AM
gezzuzz's Avatar
don;t swap used oil rings.. just use what it has till you get it..
its will break then you have none
dkler
19
Mar 13, 2010 10:53 PM
SPOON_BeIgHtEeNsEe
Aug 1, 2006 07:59 AM
NACvicSi
12
Feb 1, 2006 08:18 AM
blueskiesfade609
14
Apr 9, 2005 07:26 AM
BeavisB16
Mar 24, 2005 06:24 AM
