torque spec
Old Jan 10, 2007 | 09:19 AM
Fat Chick Magnet's Avatar
Default torque spec
after installing my friends ctr cams on his em1 SI just double checking cam plate/brace whatever its called.........the outside is 16 lb's and inside 14 lb's????? need info
and yes i did a search.
Old Jan 10, 2007 | 09:33 AM
Syndacate's Avatar
Are you talking about the top part that goes down and covers the cam?
I don't know if it's any diff but I believe if you're talking about what I'm talking about then the tq. specs are 9lb-ft on the outside sleeve and 16lb-ft on the inside parts of the cover.
Though there's two variables, one, I only know those specs from a D16Z6 so they're probably different on your B16a2, and two, I'm not sure if we're talking/thinking about the same piece, but I think we are.
Check a helms, it's sure to have it.
EDIT:
You're talking about the bolts that go through the dowel pins on the plate that actually keeps the camshaft in its journal, right?
Old Jan 10, 2007 | 09:48 AM
gezzuzz's Avatar
Default Re: (Syndacate)
for a gsr it says 7.2 and 20 ...
you would think all dohc vtec bseries motor would be the same
Old Jan 10, 2007 | 09:56 AM
when you put the cams on then you put that metal plate over the cams and it has 12 bolts.
Old Jan 10, 2007 | 09:59 AM
Syndacate's Avatar
Default Re: (dc2rtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek &raquo;</TD></TR><TR><TD CLASS="quote">when you put the cams on then you put that metal plate over the cams and it has 12 bolts.</TD></TR></TABLE>
Yeah, that's what I was talking about.
Sorry, I didn't know, on a D16Z6 they're 9ft-lb on the outside sleeve and the other 10 on the "main" piece are 16ft-lb. They're different for DOHC though, sorry bro ( @ me)
pinota
Apr 28, 2008 02:23 PM
crxpwr1
13
Feb 21, 2007 02:29 PM
bustdgst
11
Oct 21, 2006 04:32 PM
ziich2
Feb 7, 2006 07:44 AM
Darkane
Jul 27, 2004 08:46 PM
