How do you make the JDM front w/oem hid's fit into 95 integra with abs
Old Jan 10, 2007 | 06:21 AM
fasteddy91's Avatar
Default Fitmit issues, How do you make the JDM front w/oem hid's fit into 95 integra with abs
I remember seeing someone relocating the abs modulator to make the JDM oem HID's headlights to fit, anyone have the info to that or any other suggestions to make it work? For those of you who have 94-97 integras, what did you do to make them fit? thanks!
Modified by fasteddy91 at 10:28 PM 1/10/2007
Modified by fasteddy91 at 10:29 PM 1/10/2007
Old Jan 10, 2007 | 06:50 AM
Boots's Avatar
Default Re: How do you make the JDM front w/oem hid's fit into 95 integra with abs (fasteddy91)
my abs is in the same spot and i have the jdm front and my teg is a 94
Old Jan 10, 2007 | 11:24 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: How do you make the JDM front w/oem hid's fit into 95 integra with abs (boots)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boots &raquo;</TD></TR><TR><TD CLASS="quote">my abs is in the same spot and i have the jdm front and my teg is a 94</TD></TR></TABLE>
The OEM HID headlights are what causes the issue. The ABS was redesigned in '98 to accommodate the ballast on the JDM HID headlights. If you try to put them in a 94-97 car you'll have fitment issues.
Old Jan 11, 2007 | 06:54 AM
fasteddy91's Avatar
I already know it's going to be a fitmit issue, what I'm asking is for a solution. I've seen people relocate the abs modulator, does anyone have documents regarding that? thanks.
Old Jan 24, 2010 | 09:55 PM
fasteddy91's Avatar
nm, I found what I was looking for.
Old Jan 25, 2010 | 09:57 AM
Community Builder
lol what 3 years later?? Why bump the thread? How about posting the info?
Old Jan 25, 2010 | 02:25 PM
UASK20's Avatar
what if you are using a non oem hid kit.
Old Jan 28, 2010 | 09:02 PM
dothacker's Avatar
+1 on posting solution.
Old Jan 29, 2010 | 06:21 AM
vietxdragon's Avatar
do a ABS delete , that's what i did on my db8, cost about near to nothing too. Used oem brakelines from a eg and had to bend a little and cut off a fitting to replace it with the integra fitting at the master cyclinder.
Old Jan 29, 2010 | 06:36 AM
95 integra's Avatar
This is pretty funny. Gotta give it to him though, he is persistant. Most of us would have either long ago found a solution or given up.
Old Jan 29, 2010 | 07:50 AM
benjamin626's Avatar
Old Jan 29, 2010 | 08:35 AM
JDM 98 GSR's Avatar
LOL!!
Old Jan 29, 2010 | 10:34 AM
gourley's Avatar
I just did this, and I just moved my ABS Pump over a little. Just unbolt it and used some strength.
Old Jan 29, 2010 | 12:29 PM
qhondak's Avatar
After three years the guy comes back and bumps his thread.
Old Jan 29, 2010 | 12:50 PM
zedron's Avatar
Wow......Amazing.
I would have forgotten I made it.
TypeSiR-G
May 6, 2011 11:45 PM
Petah
Jun 30, 2006 07:59 PM
brad.
Feb 25, 2005 12:37 AM
