SI TO LS ?
Old Jan 10, 2007 | 04:18 AM
BrainWashed's Avatar
Default SI TO LS ?
I have a 91 hatchback with a 93LS engine , I want to use the LS ecu, isit possible to repin the sivics ecu pins to fit the LS ecu plugs with the correct codes. If so PLEASS HELP
Old Jan 10, 2007 | 04:23 AM
Pee Wee's Avatar
Default Re: SI TO LS ? (BrainWashed)
a jumper harness is what you speak of.
Your search for jumper harness returned 326 results
Old Jan 10, 2007 | 07:58 AM
crxnj's Avatar
Default Re: SI TO LS ? (Pee Wee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrainWashed &raquo;</TD></TR><TR><TD CLASS="quote">
if the ecu is obd0 it will plug right in ,,but if its obd1 you'll need to go to the junkyarh and get some obd1 ecu plugs and cut them off then solder or repin the correct wires...Theres a shitload of writeups google it
or you could use the jumper harnesses
Old Jan 11, 2007 | 04:36 AM
Default Re: SI TO LS ? (mr.speaker)
Yea but short on the money still hurting from christmas
Old Jan 11, 2007 | 04:39 AM
Already have both, the OBD-0 & OBD1. gOING TO TRY THE REPIN TODAY
90crxef
Apr 1, 2008 10:02 AM
1xfastxhatch
Jan 24, 2008 10:29 AM
3 plus 1
Feb 20, 2004 10:31 AM
wm5holla
Sep 23, 2003 01:20 PM
