Ecu Question
Well i'm about to do my motor swap and i'm in need of some money.
i have a 95 civic si and i'm swapping in obd1 b16a
I'm going to be using the p30 Ecu that came with the motor and not the p28 that is in my car correct?...i just want to make sure so i can go ahead and sell the p28. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Yes, use the P30 since you have it.
If you plan to use the P28, you need to chip it first.</TD></TR></TABLE>
also the p30 is perfect for <crome pro> i do not know why but read there is more **** for the p30 setup then with the p28 setup just with <crome pro> i read it about!
