PR3-4 is this a type-R head?
Old Jan 9, 2007 | 06:56 PM
Tiger_Si's Avatar
Default PR3-4 is this a type-R head?
Tyring to buy an R... and i am feeling a suspisous engine combo...
Thanks in advance
Old Jan 9, 2007 | 07:04 PM
Dave_B's Avatar
PR3-X where X = either 1, 2, 3, 4 is a ITR/B16 head. Look for the green paint near the distributor and the intake manifold. Also look at the trans, you should see JH4 LSD on it.
Old Jan 9, 2007 | 07:06 PM
ZygSpeed's Avatar
Default Re: PR3-4 is this a type-R head? (Tiger_Si)
What else makes you suspicious about the car?
Old Jan 10, 2007 | 08:14 PM
Tiger_Si's Avatar
Default Re: (Dave_B)
is this green paint on the back of the head or on the side?
pic will help a lot
yes, the tranny checks with a jh4 lsd, and the block has the b18c5.
is there any other visual way to check for a type R head?
Old Jan 11, 2007 | 07:28 AM
Tiger_Si's Avatar
Default Re: (Tiger_Si)
bump
visual ways to check for a Type R head?
Old Jan 11, 2007 | 07:48 AM
exies's Avatar
There is no bumping in this forums and please use the search function and go through the archives. This has been asked many times and there are plenty of threads already, I just tried searching to see what I would come up with.
Here is something to start you off with. The answer is in there and if you can't find it in the thread I linked, give the search function a try.
https://honda-tech.com/zerothread?id=553446
Old Jan 11, 2007 | 12:17 PM
Hooch'n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">PR3-X where X = either 1, 2, 3, 4 is a ITR/B16 head. Look for the green paint near the distributor and the intake manifold. Also look at the trans, you should see JH4 LSD on it.</TD></TR></TABLE>
Green paint is also on JDM B16 Heads, not just itr..........fyi
Old Jan 11, 2007 | 01:07 PM
Tiger_Si's Avatar
Default Re: (exies)
ok.
thanks for the link
anyways, for future reference, here is the pic....
hondacando
Jul 31, 2010 03:00 PM
TurboEM1
Dec 26, 2009 07:50 PM
sauceja
Oct 7, 2007 08:14 PM
5thgen4dr
Sep 27, 2007 09:31 AM
Quickridez_3
Feb 22, 2007 01:56 AM
