Car wont start! Help......
Old Jan 9, 2007 | 06:24 PM
strils's Avatar
Default Car wont start! Help......
My 95 Integra GSR will not start. When i turn the key it doesnt even try to start. I already checked the battery which is fine. I have checked and cleaned the battery terminals and the ground connections to the engine and the connections to the starter. I actually replaced the starter with a spare i have and still nothing. Any ideas?
Old Jan 9, 2007 | 06:32 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Car wont start! Help...... (strils)
did you check the ignition fuse in the under-the-hood electrical box? do your accessories power on? could possibly be an ignition switch as well...
Old Jan 9, 2007 | 06:55 PM
strils's Avatar
Default Re: Car wont start! Help...... (GRAF-FITI)
i did check the iginition fuse under the hood (50A) which is good. Accessories and everything in the car power on just fine. hmmm. ill take a look at the ignition switch. thanks
Old Jan 9, 2007 | 08:13 PM
95 integra's Avatar
How did you check the battery? Did you try jumping it? Sometimes the battery will be "dead" but still have enough juice to power accessories but not enough for the starter. Other then that, get a volt meter and check the fuse for power, then check the relay and so on until you find the problem.
Old Jan 9, 2007 | 08:19 PM
strils's Avatar
I took the battery to AutoZone and they tested it for me. I also tried jumping it and still the same thing. I swear its a wire or a fuse somewhere i am missing......ugh!!!
Old Jan 10, 2007 | 02:08 PM
strils's Avatar
Default Re: (strils)
Bump
Old Jan 11, 2007 | 02:26 PM
getfast's Avatar
Main relay?
Old Jan 11, 2007 | 06:25 PM
strils's Avatar
Default Re: (getfast)
UPDATE - FIXED!
Well after trying everything i started back at square one.....the power and ground. Ended up attaching a new ground to a new bracket and now it works. Seems as though the bracket that the main ground was attached to had corroded between it and the engine. Something new i havent seen before.....
Old Jan 11, 2007 | 08:06 PM
95 integra's Avatar
You said in your first post that you checked/cleaned the grounds though....
flood
16
Jul 12, 2013 04:40 PM
ek9sb
Jan 24, 2011 05:48 AM
EKwreckRLS
Apr 12, 2010 11:12 AM
deans96ek
Apr 23, 2007 12:08 PM
tan2
Nov 4, 2002 10:10 AM
