WHERE IS THE FUEL PUMP????
I am going to replace my fuel pump on a 93 civic ex D16z6 motor and i was needing to know were the fuel pump is located and i am replacing it with a fuel pump off a 1g dsm and what kinda modification will i have to do ( if any one has done that beforE ) and will it keep up with 550cc injectors?
thanks jared
thanks jared
why would you use a 1G dsm pump? That might not keep up with 550's either, considering the pump would be for 450cc or less, unless you got the JDM pump, which is for 510's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarven93 »</TD></TR><TR><TD CLASS="quote">well thats what i wanted to know was if itd work .. i am only gunna run 15lbs boost and i have 550cc inj. but what pump would keep up with 15lbs.</TD></TR></TABLE>
Only 15lbs?
How built is your motor?
Only 15lbs?
no i have'nt sleeved block and head is stock but i was told buy some other guys that the head will support 350 hp just fine and the block and hold 25lbs boost before getting it sleeved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarven93 »</TD></TR><TR><TD CLASS="quote">no i have'nt sleeved block and head is stock but i was told buy some other guys that the head will support 350 hp just fine and the block and hold 25lbs boost before getting it sleeved</TD></TR></TABLE>
I've never seen a stock honda block, let alone a Z6. hold 25lb's for too long ....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarven93 »</TD></TR><TR><TD CLASS="quote">thats ok caz im only going to 15lbs </TD></TR></TABLE>
I'd be wary of that. Go ask a question about your planned build in the Forced Induction forum.
