I know this has been beaten to death...but
Cool Cool Island Breezes. BOY-EE
I have a question about wheel fitment. I did try the search and i know there was a topic about wheel fitment before....but i couldnt find it. Hopefully you guys could help me out, or just point me in the right direction. I wanted to see if a 17X9 +45 would fit under my stock AP1 rear fenders (i dont wanna do any rolling ...and i really want to avoid shaving away the fender lip). I'm 1.85'' lower than stock in the rear, and i have -2.5 degrees of camber. I saw the same fitment of an ENKEI RPF1 on an AP1, but it looked pretty close to the fender. It may not rub when the car is only 1.85 inches lowered, but do you think it will rub if i lower the car some more? I dont really want to run more than -2.5 degrees of camber. I plan to run a 245-40-17 tire. thanks for any help guys.
You should barely be able to make it. A higher rear spring rate will help. Rolling of at least the inside lip of the rear fender should be done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">thats exactly what i will be running this month.. and yes it will fit... run a 245 tire...</TD></TR></TABLE>\
That's good to know. How well does it fit? does it rub at all? are your fenders rolled? could i ask more questions? lol...seriously though....how exactly do you roll your fenders? I rolled the fenders on my 240 once and it took a fender roll tool...not only did i get deathly ill after (it was winter), but i also was planning on getting the car painted, which was good, because there were mad chips, y0!
also...do you have any pics...like good detailed ones that show the space between the fenders and the tire? sorry to bother you, but i dont wanna have to send wheels back and forth because they dont fit.
245/40-17 with a 17x9 +45 is a very moderate aggressive but it looks very very good. Very Flushed.
He is my buddy Tj's car (silentdancer) with 17x9 +45 Rega Evo's. This is with -3.5 camber +roll and he was dumped like htere was no tomorrow.
Although, you can do away with the -2.5 camber, you just won't be tuckin as much though, but you'll be very close to it
Munkyw3rkz.webs.com
that whole fender roller thing i have never used.. i learned since back in the day... a wooden bat or a rubber mallet... thats how i did all my other cars.. never had a problem with any of them..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">that whole fender roller thing i have never used.. i learned since back in the day... a wooden bat or a rubber mallet... thats how i did all my other cars.. never had a problem with any of them..</TD></TR></TABLE>
The fender roller is a great tool. Results are like whoa! although, unless you wanna be a gangsta like Santos here and Use a ball bat, thats all up to you
I'd be too darn scared to take a bat to my precious AP
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBSeRiouSo »</TD></TR><TR><TD CLASS="quote">
The fender roller is a great tool. Results are crazy goood! although, unless you wanna be a gangsta like Santos here and Use a ball bat, thats up to you
ahhh you wuss....
when i do mine ill make sure to have pics taken with the bat or the mallet....
</TD></TR></TABLE>ahhh you wuss....
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt »</TD></TR><TR><TD CLASS="quote">Baseball bat FTW!!! Use a wooden one to minimize scratches, and use a heat gun to keep the paint from chipping.
that is correct, or in the sun on warm paint!
</TD></TR></TABLE>that is correct, or in the sun on warm paint!
hmm...allright fender rolling. Is there any way you could post pics of your technique or kind of a "how to" explanation? I just dont want my fender to look all wrinkled from the outside after all this is done. The size does look very nice...so i think i'd be willing to take some trouble, i just dont wanna F anything up.
Thanks "OBeseriousO" for the pic and for fading my name. lol jk.
Munkyw3rkz.webs.com
well its a lil by lil process... you dont wanna fold it all in one shot... so taps from the front and tap to the rear or vis versa.. hit it so you can see it "roll" slightly and work your way back adn forth till u reach your disired roll...
orrrr
as some have done and i have as well...
with a wooden bat...
jack up the car just enough to clear the bat in there... and with the bat pressed against the lip and using the tire/rim as leverage person #2 lowers the car "SLOWLY" and that section will be rolled......
orrrr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">
Thanks "OBeseriousO" for the pic and for fading my name. lol jk. </TD></TR></TABLE>
hahaha. I got 2 years on yah
Remember, "often imitated, but never duplicated"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">well its a lil by lil process... you dont wanna fold it all in one shot... so taps from the front and tap to the rear or vis versa.. hit it so you can see it "roll" slightly and work your way back adn forth till u reach your disired roll...
orrrr
Hmm the bat thing sounds more risk-ay. But the mallet thing sounds a little violent as well. Which method have you had the best luck with? do your fenders ever get all folded and wrinkled from the outside when you do this? Also, how much camber are you running on your set up? When you say "back to front" do you mean the outside of the fender and the inside of the fender, or are you referring to back and forth INSIDE the wheel well? Thanks for answering all the questions so far. I really appreciate all the help
orrrr
</TD></TR></TABLE>Hmm the bat thing sounds more risk-ay. But the mallet thing sounds a little violent as well. Which method have you had the best luck with? do your fenders ever get all folded and wrinkled from the outside when you do this? Also, how much camber are you running on your set up? When you say "back to front" do you mean the outside of the fender and the inside of the fender, or are you referring to back and forth INSIDE the wheel well? Thanks for answering all the questions so far. I really appreciate all the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBSeRiouSo »</TD></TR><TR><TD CLASS="quote">245/40-17 with a 17x9 +45 is a very moderate aggressive but it looks very very good. Very Flushed.
well thats about as low as my car is also. I really dont wanna resort to having to use -3.5 degrees of camber...at that point it would probably diminish handling. although that car doesnt really look like -3.5...are you sure its that much?
Munkyw3rkz.webs.com
i mean from the inner of the fender, and no there has never been any damage to the outside.... you wouldnt know it unless stuck your head into the tire well....
last time i checked i was at 2.0 front 1.5 rear but im slightly lower then i was at that time.. im goign to redo everything in the coming weeks
</TD></TR></TABLE>i mean from the inner of the fender, and no there has never been any damage to the outside.... you wouldnt know it unless stuck your head into the tire well....
i used a dremel and about 5 bits for the rears. I cut them out because i dont like rolling since the paint will eventually crease if done improperly.
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge »</TD></TR><TR><TD CLASS="quote">i used a dremel and about 5 bits for the rears. I cut them out because i dont like rolling since the paint will eventually crease if done improperly.</TD></TR></TABLE>
yea thats another option but since they are scared of the bat and mallet i doubt they will want to cut..
I aint never scared. Maybe im a little scared. but still...I'd be willing to do either cutting or rolling. I just wanted to get the methods right so i dont mess up my car, thats all. The only problem with cutting is that you'd have to remove that rubber strip from the inside of the fender, and it also makes you way more prone to rust. Although i may have to take the rubber strip out anyway since i'd want to check the paint for chipping...and maybe it wouldnt stay in there right after rolling. Just out of curiosity, aren't S2000 rear fenders bolt on?
</TD></TR></TABLE>I aint never scared. Maybe im a little scared. but still...I'd be willing to do either cutting or rolling. I just wanted to get the methods right so i dont mess up my car, thats all. The only problem with cutting is that you'd have to remove that rubber strip from the inside of the fender, and it also makes you way more prone to rust. Although i may have to take the rubber strip out anyway since i'd want to check the paint for chipping...and maybe it wouldnt stay in there right after rolling. Just out of curiosity, aren't S2000 rear fenders bolt on?
Munkyw3rkz.webs.com
I aint never scared. Maybe im a little scared. but still...I'd be willing to do either cutting or rolling. I just wanted to get the methods right so i dont mess up my car, thats all. The only problem with cutting is that you'd have to remove that rubber strip from the inside of the fender, and it also makes you way more prone to rust. Although i may have to take the rubber strip out anyway since i'd want to check the paint for chipping...and maybe it wouldnt stay in there right after rolling. Just out of curiosity, aren't S2000 rear fenders bolt on? </TD></TR></TABLE>
no they are tac welded.....
you can also do a mix and cut the lip very 3-5" and fold it in sections ... easier to roll that way
you can also do a mix and cut the lip very 3-5" and fold it in sections ... easier to roll that way</TD></TR></TABLE>
yeah i was thinking about doing it that way so the metal doesnt really have to stretch as it folds.
Munkyw3rkz.webs.com
last time i checked i was at 2.0 front 1.5 rear but im slightly lower then i was at that time.. im going to redo everything in the coming weeks</TD></TR></TABLE>
said it earlier
said it earlier
ah so. sorry about that. well thats good...like i said, I dont really want to go any further than -2.5 degrees. I may back it off a quarter degree or so if i can....iduno, I guess we'll see.
