Correct way to Space your Hood.
Old Jan 9, 2007 | 04:35 PM
Spo0NFed E M 1's Avatar
Default Correct way to Space your Hood.
Im looking to space my hood by the windshield (like done on cars w/ ITB's). JW the correct way its done and with what type of washers or spacers. I currently have 4 large washers but it still doesnt have enough lift as I want. Anyone have pics, info or even a link that would be great. TIA.
Old Jan 9, 2007 | 04:37 PM
Eran's Avatar
HT White Ops
The correct way is to not do it
Just get some more washers and longer bolts.
Old Jan 9, 2007 | 04:38 PM
bart2546's Avatar
Default Re: Correct way to Space your Hood. (all mtr em1)
Best thing I could think of is using stainless steel washers so none of them rust, and use ones that are snug to the bolt so you don't have play back and forth.
Old Jan 9, 2007 | 04:39 PM
williejohnson's Avatar
New User
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">The correct way is to not do it</TD></TR></TABLE>
RICE
i did this once with just longer bolts and washers but everyone kept saying my hood was fu*ked up so i just made it stock again
Old Jan 9, 2007 | 04:40 PM
Padawan's Avatar
Darth ModerVader
If you really want to do this, also make sure that you are using the correct grade bolts, not just whatever you find at the hardware store.
Old Jan 9, 2007 | 05:43 PM
BlueIntegraBoy's Avatar
Default Re: (solbrothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers &raquo;</TD></TR><TR><TD CLASS="quote">yeah hella washers and longer bolts!!
Looks like you got a stack of dimes.
Old Jan 9, 2007 | 06:27 PM
trrbl1bmx's Avatar
if you do this to your car, and you pop your hood to find a d series with bolt on's you should be slapped!
Old Jan 9, 2007 | 06:28 PM
Eran's Avatar
HT White Ops
Default Re: (p00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p00n &raquo;</TD></TR><TR><TD CLASS="quote">if you do this to your car, and you pop your hood to find a d series with bolt on's you should be slapped!</TD></TR></TABLE>
If you're sitting in the car and can't see velocity stacks .... you should be slapped.
Old Jan 9, 2007 | 06:29 PM
turboDeznutz's Avatar
Default Re: (p00n)
i lol'd
Old Jan 9, 2007 | 07:16 PM
EJgsr's Avatar
Default Re: (Eran)
If you're sitting in the car and can't see velocity stacks .... you should be slapped.</TD></TR></TABLE>
it could be used if you want your under hood temps to go down...
this mod is still a
Old Jan 9, 2007 | 07:20 PM
alacard's Avatar
this topic has been beaten and beaten and turned over and beaten again. one word: "search"
Old Jan 9, 2007 | 07:58 PM
Ichigo's Avatar
it stupid because you make it easier for theives to cut your battery cable and steal your car. DUh!
Old Jan 9, 2007 | 08:14 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: (Ichigo)
this is sooo lame. ive heard it being called the "jdm hood prop" and etc.. i think its lame and i dont really see how functional this really is
Old Jan 9, 2007 | 08:37 PM
EM1SON's Avatar
Default Re: (spock_rocker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">this is sooo lame. ive heard it being called the "jdm hood prop" and etc.. i think its lame and i dont really see how functional this really is</TD></TR></TABLE>
x2
Old Jan 9, 2007 | 08:41 PM
Jimmy's Avatar
Global Moderator
How the hell did this turn into.. how lame it is to space your hood for haters. All your doing is making this thread off topic.
Old Jan 9, 2007 | 09:20 PM
electric-boost's Avatar
I have seen a few cars with this mod and always thought they did a large displacment swap and actually NEEDED to do it ie...function.
Old Jan 9, 2007 | 09:23 PM
Jtuned DC2's Avatar
* B A N N E D *
you could use a set of Do do's. those rubber bushing that go on skateboards. work fine.
Old Jan 10, 2007 | 07:39 AM
Yea I have some SS washers as of now but I'm going to the hardweare store now to get some nylon spacers or rubber Do Do's....Any ideas other than that? size,
Old Jan 10, 2007 | 07:42 AM
mike1114's Avatar
Default Re: (all mtr em1)
DONT DO IT
Old Jan 10, 2007 | 08:10 AM
bart2546's Avatar
Default Re: (mike1114)
I think if you have a turbo setup it or anything that's going to generate a larger amount of heat than stock, it wouldn't be a bad idea just don't make it stick up like 4 inches, a half inch to an inch AT MOST should suffice. And if you don't wanna do that, just take off the gasket thing that runs along the hood and bottom of windshield area.
Old Jan 10, 2007 | 08:18 AM
2coupes's Avatar
this topic has been butchered to death, search next time
nylon spacers
Old Jan 10, 2007 | 08:53 AM
eg-owns you's Avatar
Default Re: (Jimmy)
do not get washers they look like ****. i have a longer bolt and a metal dowl over the bolt. dont make it to high eather looks retarted i only did it so my engine would stop hitting my damn hood
and its proven that it does not help your engine temp at all not one bit it actually makes the inside hotter the hot air will just stay in there kinda like wirld wind effect.
Old Jan 10, 2007 | 09:19 AM
WhiteOnRice's Avatar
This = s.h.i.t. Spacers would have worked better but the only justifiable reason to go this is a H in a civic.
Old Jan 10, 2007 | 11:24 AM
guywitaDA's Avatar
thats a lot of washers.... i mean do you really need that much room......
Old Jan 10, 2007 | 03:06 PM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ichigo &raquo;</TD></TR><TR><TD CLASS="quote">it stupid because you make it easier for theives to cut your battery cable and steal your car. DUh!</TD></TR></TABLE>
do the theives have like 1 cm thick hands and arms
buyt the best thing to use is a nylon spacer and longer bolts , non of that ghetto bullshit stack of washers
