Car shaking...
Old Jan 9, 2007 | 03:54 PM
standbackimapro's Avatar
Default Car shaking...
i got a 91 ef ... It has new shocks and struts in the front, I notice the car to shake alot in 3rd gear around 60 mph.. Also when i start slowing down i notice it shakes alot also..
car has new brake pads but not rotors, but the rotors arnt bad, also the right cv boot is ripped...
Old Jan 9, 2007 | 03:58 PM
clutchpoppin0723's Avatar
Default Re: Car shaking... (standbackimapro)
your tires probly need to be balanced.... and you might wanna change that cv axle before it gives out...
Old Jan 9, 2007 | 04:41 PM
Jonny Rocket's Avatar
Does it shake more on da steering wheel or on da brake pedal.
If its the steering wheel. You will need to balance your tires or tires could be messed up. cv-shaft/axle might be bad.
If its on da brake pedal. You have warped rotors. Need to replace them
Old Jan 9, 2007 | 05:29 PM
blah13's Avatar
Default Re: Car shaking... (Jonny Rocket)
Definately sounds like wheel balance.
If it also shakes when braking take it to a brake shop and have them check your rotors. Theyre not warped, its usually caked on brake pad material and if you catch it early enough the rotors can be turned to fix the problem.
sagacious
14
Jul 29, 2012 08:56 AM
josiah965
12
Nov 13, 2009 05:00 PM
noss88
18
Nov 26, 2008 11:55 AM
E36 Guy
Oct 17, 2004 06:09 AM
RacerXintegra2k
Sep 25, 2002 05:03 PM
