Fuse Keeps Blowing
Old Jan 9, 2007 | 02:21 PM
USDMSiR's Avatar
Default Fuse Keeps Blowing
ok, so i just changed my headlight bulbs (passwordjdm ultra white) cause my other ones burnt out. I have JDM headlights by the way. After that my dash lights/tail light fuse keeps blowing. I have no clue what to do. i tried grinding the connectors for the light box grounding thing behind the headlights and i soldered a red wire that was frayed that was coming out from my stereo. it had a tag marked ACC on it but that didnt help either. and my corner lights and side markers dont work either. im wondering if they are on that fuse as well. thanks in advance.
Old Jan 9, 2007 | 02:24 PM
jgb989989's Avatar
Default Re: Fuse Keeps Blowing (USDMSiR)
Check all the wiring associated with the lights
most like you have a hot wire grounding on the chassis
Old Jan 9, 2007 | 04:58 PM
ED6JDM's Avatar
Yo! this happened to me already. Check your stereo ground or power it could be touching. I hit a bump last month and my fuse #12 keep blowing and when I took the stereo out i found that my ground wire was loose and touching my power wire.
Old Jan 9, 2007 | 05:28 PM
Crx Jimmy's Avatar
Default Re: (ED6JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED6JDM &raquo;</TD></TR><TR><TD CLASS="quote">Yo! this happened to me already. Check your stereo ground or power it could be touching. I hit a bump last month and my fuse #12 keep blowing and when I took the stereo out i found that my ground wire was loose and touching my power wire. </TD></TR></TABLE>
check the stereo first, the headlights have their own fuses independent of the side markers so that should have nothing to do with it, I would look at the stereo
blackakkord
Jan 31, 2008 05:46 PM
g0tgot
Jul 4, 2007 05:03 PM
CaseBone
Mar 13, 2006 04:57 PM
1990crx
14
Apr 12, 2005 12:28 PM
