Severe Bogging
i have a 2001 accord 4cyl(f23). The car is turboed and ive recently be seeing a problem. When im in any gear and i hit the gas the car will bog out, the turbo will spool and then if i hold it long enough it will give alittle pop in the exhaust mani and while this is happening the car is going no where. I have the blox map adapter and a fmu..so i thought they might be the problem...so when i took them off...the problem got worse..now instead of it happening sometimes...its happeniing all the time when i give it more than about half throttle...somone let me know the problem
did it ever run correctly? if not you might need to invest in stand alone engine managment before you blow your motor. (remember im not boosted, just speculating)
yea it was running fine till recently...i got a AEM EMS ready to install...but i wanted to correc the problem before i start tuning
thatkid
Jul 3, 2008 02:41 PM
