who understands IAB?
Old May 14, 2002 | 05:10 PM
shivic's Avatar
Default who understands IAB?
is the iab ecu controlled or vaccuum controlled.
Does it stay closed untill the ecu opens it at a certain rpm,
or is it always open unless you have an ecu that deals with iab and that closes.
i ask this because my h22a makes peak power at 5000 rpms.
please help.
Old May 14, 2002 | 11:46 PM
94GSRRacer2's Avatar
New User
Default Re: who understands IAB? (Jonesy69)
idle air bypass solenoid = IAB..... read it here... http://www.promustangs.com/tbclean.html
Old May 15, 2002 | 01:17 AM
aeolus's Avatar
Default Re: who understands IAB? (94GSRRacer2)
The iab system is controlled by the ecu and vacuum pressure.Impretty sure for a h22a,there supposed to open at 4600 rpms.
Old May 15, 2002 | 07:35 AM
shivic's Avatar
Default Re: who understands IAB? (aeolus)
so if you don't have the right ecu for the iab. it just stays open the whole time.
Old May 15, 2002 | 09:25 AM
DirtyLude's Avatar
Actually the IAB is Intake air Bypass and it's the butterflies that open and close in the second runners of the intake manifold. The Idle Air Control Valve is called an IACV on Honda's, which controls idle speed.
The IAB is actually turned on at low rpms and turns off at high rpms. If you disconnect the vacuum line or disconnect the wire to the ECU the butterfly valves will stay open all the time, so unless they're stuck, they should be open and cause low end power loss, not high end power loss.
The ECU sends a signal to the IAB solenoid which uses vacuum to hold the butterfly plates closed until 4900 rpm when it turns the solenoid off, letting the plates open up.
Old May 15, 2002 | 02:32 PM
New User
Default Re: who understands IAB? (DirtyLude)
oops
[Modified by 94GSRRacer2, 3:33 PM 5/15/2002]
boydsc33
Aug 23, 2012 06:27 AM
fenix4o9
Feb 25, 2010 11:03 PM
altran
Jan 31, 2008 09:53 AM
pikappaphi
Mar 29, 2004 07:39 PM
94SiSQO
May 3, 2002 02:46 AM
