idle to low!!!!!!!
the idle is low ...it wants 2 die but it dosent...idle so low that my oil light comes on....and yes i have enough oil...im not new at this i juss cant figure this out....i started after i closed the mechanical idle/air controll valve under the throdel body...i have a 91 ls intake manifold an a 92 head....would that make a diference????i dont really think so but i cant figure it out....HELP!
justin
justin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">Have you adjusted your idle screw? Or is the IACV bad or damaged?</TD></TR></TABLE>
What I was gonna say...
just untighten your TPS sensor so it's alittle loose, have a buddy start the car and you move the tps till it idles at were your friend tells you to stop should be around 7ish and than tighten it. That should do it.
