Honda S2000 Honda S2000
Espelir or H&R??
Old Jan 9, 2007 | 10:12 AM
Rahjahdat's Avatar
Default Espelir or H&R??
What's up guys? I need everybodys opinion on which of these springs to get for my AP1. I've tried searching but nothing came up, I tried S2Ki's search engine but seems like it doesnt work very well. Now this is my daily driver, I have no intentions of tracking my car (maybe later). I'm just looking for a nice spring w/ a nice drop, not too low not too high. Now I was in the middle of purchasing the Espelir springs until somebody mentioned the H&R springs. Maybe you guys can help me make up my mind on whice one to get. If you guys have any pictures of your car w/ either spring on stock shocks please post em' up. Any input of either spring would be good too
Old Jan 9, 2007 | 12:51 PM
JDM knowledge's Avatar
Default Re: Espelir or H&R?? (Rahjahdat)
i like the Espelir just because my buddy had them and they were not too bad for just a spring.
Old Jan 9, 2007 | 02:27 PM
Rahjahdat's Avatar
Default Re: Espelir or H&R?? (JDM knowledge)
How does the stance look? Did your buddy say how the ride quality was?
Old Jan 9, 2007 | 04:29 PM
Mr. Projekt's Avatar
* B A N N E D *
The Espelirs very well. It lowers the front and rear to approximately the same ride height, so there's no rake to it (front lower than rear).
Old Jan 9, 2007 | 06:19 PM
Rahjahdat's Avatar
Default Re: Espelir or H&R?? (Mr. Projekt)
Thanks guys, looks like Espelir it is.
Oh yeah, what website sells them? I found 1 website but it said they were currently out of stock. Let me know guys, thanks a lot for your input.
Old Jan 9, 2007 | 08:07 PM
iam7head's Avatar
try s2ki.com, i think william from e-autosport sells then for 180ish.
get them before they runs out
one thing those the spring rate is much higher than stock springrate so don't expect the stock damper to handle the additional pounding under load
Tein S-Tech:
Fr: 297(5.3) - Rr: 364(6.5)
Eibach Pro-Kit
Fr: 262(4.67) - Rr: 342(6.1)
Espelir Active Super Down
Fr: 313.6(5.5) - Rr: 392(7.0)
KG/mm sport:
Fr: 398(7.0) - Rr: 448(8.0)
Neuspeed:
Fr: 280(5.0) - Rr: 215(3.8)
OEM:
00-01 - Fr: 218(3.9) - Rr: 291(5.2)
^data from s2ki.com
Old Jan 9, 2007 | 08:51 PM
Rahjahdat's Avatar
Default Re: Espelir or H&R?? (iam7head)
Wow thanks for all those specs. Well if that's the case, I hear KY is a good combo w/ the spring. If this is true then the stock dampers will be replaced later on down the road when the stockies go out. One more question, is this setup good for daily driving?
Old Jan 10, 2007 | 01:27 PM
NytRyder2k1's Avatar
I just purchased my s2000 2 weeks ago and dropped it on the espiler springs with koni shocks. Perfect drop with the oem rims and rides fairly smooth. If you plan on getting aftermarket wheels bigger than 17s than you will probably have issues with rubbing unless you roll the fenders. Im gonna take some pictures tonight so ill try to post them up for you. Good luck
Old Jan 10, 2007 | 07:58 PM
Rahjahdat's Avatar
Default Re: Espelir or H&R?? (NytRyder2k1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NytRyder2k1 &raquo;</TD></TR><TR><TD CLASS="quote">I just purchased my s2000 2 weeks ago and dropped it on the espiler springs with koni shocks. Perfect drop with the oem rims and rides fairly smooth. If you plan on getting aftermarket wheels bigger than 17s than you will probably have issues with rubbing unless you roll the fenders. Im gonna take some pictures tonight so ill try to post them up for you. Good luck </TD></TR></TABLE>
Hell yea! post up those pics man. If I get any wheels they're not going to be any bigger then 18's. I'm about to purchase an OEM lip here pretty soon, is there enough clearance if I put it on. If not then I'm not gonna get the lip. You guys are the breast!! Thanks a lot. Honda-Tech FTW!
bopbop93030
Suspension & Brakes
Dec 28, 2008 05:46 PM
xiong28
Suspension & Brakes
Apr 7, 2008 07:02 AM
MrXclusivE
10
Apr 4, 2008 12:07 PM
JDMKid71
Suspension & Brakes
10
Nov 8, 2005 07:14 AM
garados
Feb 5, 2002 02:41 PM
