NO Start 94 Integra LS Can Anyone Give Some Suggestions
Old Jan 9, 2007 | 09:28 AM
Meesterzoomak's Avatar
Default NO Start 94 Integra LS Can Anyone Give Some Suggestions
I have a 94 B18 integra, the problem is that my car stalled and then it wouldnt start back up, I checked for fuel, it has it, i changed the cap rotor, plugs, wires, and fuel filter before i knew bout it gettin fuel cuz it was old. What could the problem be, if any is it common? I mean it could be ignition, it could be my distributor, it could be a fuse or relay, but im not sure. Has anyone experienced this in the past with their cars? Please let me know thanks.
Rich
Old Jan 16, 2007 | 07:12 AM
EGSix757's Avatar
Default Re: NO Start 94 Integra LS Can Anyone Give Some Suggestions (Meesterzoomak)
wen it stalled out did you notice if the rpms went strait to 0 or did it like bog and die?
ifyour rpms went strait to 0 then its your igniton check fuses, relay, and igniton switch.
Old Jan 18, 2007 | 09:53 PM
Default Re: NO Start 94 Integra LS Can Anyone Give Some Suggestions (EGSix757)
It went straight to 0 just like as if it were tunring off normally. I have yet to check the fuses cuz my car is covered in ice ha, but i have definitely considered that as well as the distributor,i have to check for spark and compression still. Thanks for the suggestions, if you have any other suggestions let me know.
Old Jan 18, 2007 | 10:03 PM
sdinteg's Avatar
my guess is your ignition coil in the distributor. do a search on how to check for spark. also be aware that you can burn out your coil if you check for spark improperly... i had to learn the hard way =\
Old Jan 24, 2007 | 10:57 PM
bump
Old Jan 25, 2007 | 04:19 AM
94LS4teg's Avatar
Check if you have gas in your injectors. Maybe the gas pump is the trouble. If your fuel filter was too dirty, that could overheated the pump, and shortened its life. If you have fuel pressure in your fuel rails, then, denifitely somthing is wrong with the ignition system.
I used to have a 88 teg, and happened the same thing. The problem was the ignition module that is inside of the distributor.
Guess this helps
Old Jan 25, 2007 | 04:25 AM
mike5809's Avatar
Default Re: (94LS4teg)
I would suggest distributer.
We will need more info though; is it getting spark, fuel, etc?
Does it crank, turn over? stuff like that.
Moyita
Jan 11, 2018 03:14 AM
redcivic
Dec 26, 2011 07:40 PM
Kneedraghonda
Apr 7, 2010 03:54 PM
live_again_integra
Jan 4, 2007 05:42 PM
94redintegra
Aug 2, 2005 09:36 AM
