Make my idea come true
Ok im not good of being electric so im asking for help with my idea, i want to make a kill switch for my 93 prelude in main switch or whatever it called, i dont know if anyone done it but it would be a great if anyone can help me out on finding the wiring that goes to the switch so i can disconnect them and connect the kill switch for fuel pump and ill need help in kill switch too but ill be fine on it i think, ill read some treads later on it. (sorry for the crappy pictures was taking from my phone)
thank you
thank you
I do not think you would want to use that switch. You can use a regular switch though. Get a 2 pole switch, cut the red wire that is going to your resistor box.The resistor box is near your clutch master cylinder on the drivers side, unless you car is right hand drive. Install the switch in line with the red wire going to the resistor box. All this does is kill power to the injectors.
DC2*Integra
Audio / Security / Video
Apr 6, 2010 08:28 AM
hatchinprogress
Aug 27, 2004 05:09 PM
