hooking up the o2 sensors..
Old Jan 8, 2007 | 09:56 PM
crazy4hp's Avatar
Default hooking up the o2 sensors..
i'm using a automatic motor converted to a 5spd. the motor is a 98 sohc vtec. and the tranny is a 98 5spd. the harness is a 99 in a 99 hatch ek.
the plugs don't fit. like a male to male plug. instead of a female and male plug.
and the cat o2 sensor.... would i have to wire that straight to the ecu or what..?
help plz...
Old Jan 9, 2007 | 09:37 AM
Chim Chim's Avatar
Default Re: hooking up the o2 sensors.. (crazy4hp)
Which connector are you having a problem with? The 02 sensor plug from sensor to engine bay harness are the same across the board between auto and manual... Assuming that you're talking about the sensor to engine harness plug, the o2 sensor in the cat just needs extended wires to plug into the secondary o2 sensor plug just in front of the of distributor or an extension harness... Pictures would help...
PhantomPharter
Oct 29, 2012 03:29 PM
appelsos
Jul 21, 2011 12:23 AM
BlueShadow
Jan 16, 2005 11:04 AM
SpeedDreamz.com
Nov 9, 2003 08:01 AM
