Reflashing the ECU?
I don't know how true this is, but I've heard that after modifications (like I/H/E) having the ECU reflashed will help with performance and gas mileage. Any Truth to this? Also I've been having a CEL for an o2 sensor keep coming back, all new sensors and the wiring is fine. I was told that having the ECU reflashed will cure this since it resets all the paramiters (sp?) of the ecu and re-learns the ECU to the current settings?
Is Honda the only place that can reflash the ECU? and is their any truth to this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">there is no way of "flashing" or modifying OBD2 ecus
what brand O2 sensor are you using??</TD></TR></TABLE>
You can reflash obd2 ecus, it costs LOTS. and the only ppl that might have the tom gear is a dealership. or maybe some rich tunner basterd.
simply unplugging the ecu will reset it.
No, a new bin will not fix your problem.
its either your sensor, wiring. reset the ecu and see what happens
As far as I know, only OB2a (96-98) can be reprogrammed... There's a couple places that I can think of, InlineFour and Erick's racing... So your options are to convert to OB2a or OB1 if you want ECU work done. Another option is to run a piggyback like a VAFC or E-manage, etc...
BoostJockey
23
Feb 7, 2014 04:42 PM
Legion
Jun 12, 2011 06:36 AM
