Need help wiring sensors.
Old Jan 8, 2007 | 08:44 PM
tuname420's Avatar
Default Need help wiring sensors.
ok i ordered a boomslang harness, cuz my other obd0-obd1 didnt have the right wires coming out for dpfi and dizzy.im still waiting for it to come but i kno how to do the injector wiring and ****. so my questions are.
1. Does the d15b2 have a knock sensor???Its a black boot on my 90 dx with 2 wire terminals inside it which the y7 block doesnt have a sensor for it.
2. There is also a little black connector on the harness that is by the starter does anyone kno where this hooks up.
3. Can anyone tell me the color wires for the intake air temp sensor and aecv sensor.
sorry i didnt label **** like i should have. and its been along time since ive built my engine.
THANKS EVERYONE FOR ANY HELP.
Old Jan 8, 2007 | 09:35 PM
tuname420's Avatar
Default Re: Need help wiring sensors. (tuname420)
bump
Old Jan 8, 2007 | 11:36 PM
Rywire's Avatar
Shoulda saved money and ordered my harness...
BUT ill help anyway
1. no
2. ??????????
3. iat is red/yel and grn/wht eacv is blu/yel and blk/yel
Old Jan 9, 2007 | 01:25 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Need help wiring sensors. (droppedcrxsi)
1. No, the connector is the fan switch, the Y7 should have a new switch style on the thermostat housing. You'll need to extend these wires to there and wire up a plug.
2. Is it a ring terminal like a ground or a flat connector? If you can get me a pic I'll let you know
3.what he said above
Old Jan 9, 2007 | 09:26 AM
tuname420's Avatar
the sensor is next to the oil pressure sensor. i saw it in a pic somewhere for a d15b2.
then for the 2 wires near the starter are grounds. one female plug and one is a round hole one. i think one might go on the clutch cable bracket on the trany.
Old Jan 9, 2007 | 11:07 AM
Technical Hero
This is the plug on the old one (right pic) and run the wires to a plug on the thermostat housing on the Y7 (left pic). If the block has a bolt on a coolant passage on the back you may be able to just swap the D15 sensor onto the Y7 block.
Old Jan 9, 2007 | 11:15 AM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuname420 &raquo;</TD></TR><TR><TD CLASS="quote">2. There is also a little black connector on the harness that is by the starter does anyone kno where this hooks up.
if it's a ring terminal i'm thinking t-stat ground.
if it's a spade connector it connects to the starter.
Old Jan 9, 2007 | 08:09 PM
tuname420's Avatar
thanks, im using a p28 so im guessing i dont need that sensor so i bought a 90 thermostat housing. and ya i looked at a car at the junkyard and its to the starter and thermostat housing as u said. thanks guys.
becauseracecar8
Feb 15, 2016 11:16 AM
tibss
Jan 31, 2008 11:28 PM
Jap_Spec_Imports
Nov 22, 2007 11:33 AM
tur3oDC4
Aug 10, 2005 02:35 PM
CTRbOy
Feb 12, 2004 11:13 AM
