Where is the horn located?
Im installing keyless entry on my girlfriends civic and I need to connect the a wire to the horn for the alarm. Im wondering where the horn is located on a 2003 civic. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ct991 »</TD></TR><TR><TD CLASS="quote">Well I'm assuming it's the same place as my 2002...it's behind the bumper on the driver's side.</TD></TR></TABLE>
So im guessing that Im going to have to take the bumper to get to the horn?
i have an 03 ex ...when i took off the bumper to put in my headlights i found the horn right under the 'front 'bumper' support' on the driver's side
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic62 »</TD></TR><TR><TD CLASS="quote">I have the same question so I'm wondering if you can just remove the headlight if you are replacing the horn... Sorry for cutting in... </TD></TR></TABLE>
to remove the headlight you have to remove the front bumper....sorry bud
first time installing a alarm/keyless entry system on a car? When you wire up the horn, you dont manually take off the bumper and run the wires to it. The best thing to do is find the wire from somewhere under the dash. It's most likely a neg switch wire too.
http://64.85.6.118/diagrams/diagrams.asp
click on honda, then go to civic 2006. it shows you where the wire is and what color.
90da4dr
Sep 8, 2006 08:04 PM
Keith P
12
Apr 25, 2005 04:17 PM
