intake manifold need help
i have and obd2 B16A trying to convert to obd0 i have a JG Edelbrock intake manifold and i want to kno if i can use it in my obd0 swap. im not sure if my Si crx harness plugs up to the idle speed control that came with the motor. plus the throttle body has a tps sensor on it and it has another sensor on it which i dont kno what its for
yes you can make the motor obd0 just get obd0 injectors and extend the map sensor wired to reach the tb. and obd0 alternator and dizzy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A CRX »</TD></TR><TR><TD CLASS="quote"> idle speed control that came with the motor. </TD></TR></TABLE>
what are you talking about? the iacv? if so yes an si harness will plug into it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A CRX »</TD></TR><TR><TD CLASS="quote">plus the throttle body has a tps sensor on it and it has another sensor on it which i dont kno what its for</TD></TR></TABLE>
all tb's have a tps and the other sensor is the map sensor remove the one on your firewall and use this one.
mutantmopar
Aug 2, 2007 03:06 PM
Archetypical_hybrid
May 22, 2005 09:20 AM
