motor mount Q's
I got the energy suspension motor mount insert kit. I guess they only make the front insert. Well I was reading the insructions (dont know why) and is says not to use with a severly damaged motor mount. Well I go open the hood, take a look,
man I should have done this long ago, its busted, busted, busted!!! Well I have a question, are the bolt or nut welded or fixed somehow. I couldn't get a wrench or socket in on the header side, and a 2" bar didn't want to budge the other side, I think, I broken tooo many bolts and sockets to try any harder without knowing the answer.
The nut (header) side has a little tab that keeps it from spinning (why I don't know). You can only loosen it from the other (away from the header) side.
edit: doh!
I see you already tried loosening that side. It might be just stuck. I had no trouble loosening that bolt on my car. Try some wd-40.
[Modified by weekendracer, 8:15 PM 5/14/2002]
edit: doh!
I see you already tried loosening that side. It might be just stuck. I had no trouble loosening that bolt on my car. Try some wd-40.[Modified by weekendracer, 8:15 PM 5/14/2002]
