Inspection related problems
Old Jan 8, 2007 | 05:57 PM
ghostrider dc2's Avatar
Default Inspection related problems
Aright guys i just got a 98 hatch and i tried to pass my state somke inspections and i failed for this :
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
P0420 Catalyst System Efficiency Below Threshold
P0505 Idle Control System Malfunction
P0509<<<< I dont know what this code is
how can i fix this codes , so i can pass my emissions?
And can i just go back and reflash my ECU to pass them?
TIA Dan
Old Jan 8, 2007 | 05:59 PM
Eran's Avatar
HT White Ops
Your MAP sensor is hooked up wrong ..... or dead.
You need a new catalytic converter.
Clean out your IACV.
P0509 is another IACV problem (high voltage).
Old Jan 8, 2007 | 06:08 PM
Default Re: (Eran)
are you sure that is the catalyc converter instead of being the O2 sensor?
and what's? and how do i clean the IACV?
Old Jan 8, 2007 | 06:26 PM
Eran's Avatar
HT White Ops
Default Re: (ghostrider dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghostrider dc2 &raquo;</TD></TR><TR><TD CLASS="quote">are you sure that is the catalyc converter instead of being the O2 sensor?
and what's? and how do i clean the IACV?</TD></TR></TABLE>
You could do a search ..... that might be worthwhile.
Old Jan 8, 2007 | 06:38 PM
Default Re: (Eran)
i did , i still dont really know how the part looks like but i get the idea
Old Jan 8, 2007 | 06:49 PM
Padawan's Avatar
Darth ModerVader
Default Re: Inspection related problems (ghostrider dc2)
Can you elaborate on your setup a bit? Is the car completely stock?
xfrankix2
12
Sep 12, 2007 08:10 PM
fullraceacura
Mar 30, 2005 06:15 PM
sshaikh01
May 31, 2003 08:57 AM
