Swapped b18b into EK, Throttle Body problem
Old Jan 8, 2007 | 04:22 PM
chineseflyrice's Avatar
Default Swapped b18b into EK, Throttle Body problem
So I finally got the b18b into my EK hatch. When I fired it up, the car starts and then sputters and then stalls. I tried starting it numerous times and it still doesn't start up. I used the Integ Ecu and Throttle body. Here's the weird thing though. When I swapped back the civic d series throttle body back on there with the integ ecu, the car starts up fine . It's weird... has this ever happen to anyone else? Anyone know how to fix it? Thanks for the help guys.
Old Jan 8, 2007 | 04:30 PM
dustinO's Avatar
Check out your TPS sensor. Is working properly
Also, make sure your TPS and MAP sensor plugs are not switched around.
Modified by integraca at 6:22 PM 1/8/2007
Old Jan 8, 2007 | 04:39 PM
pdiggitydogg's Avatar
^bingo
Old Jan 8, 2007 | 04:44 PM
Default Re: (pdiggitydogg)
yea, i tried switching the plugs, still no good... Do you guys think I would need to buy a new TPS sensor?
Old Jan 8, 2007 | 04:48 PM
no_rice_please's Avatar
if you switch the plugs and it wasn't that then
it must be the senors try that and report back
ekhatch66
Aug 13, 2009 08:21 AM
CSHornet60
11
Apr 14, 2007 08:05 PM
chineseflyrice
Feb 17, 2007 06:49 PM
chineseflyrice
Jan 23, 2007 07:06 AM
singlestic
Northwest (Sales)
Oct 5, 2006 10:12 AM
