DA FRONT SWAY BAR
ok so the other day put on my rear integra sway bar and it fit....no problem....but the front is a little different....the mounting bushings to the chassi don't really fit.....but i was woundering....are there any out there that have a da integra front sway bar.....aslo list what kind of fabing if any yall had to do.....
pix also...thanks
pix also...thanks
the 23mm K rubber bushings should fit. you dont use the DA bracket tho. just the rubber bushing, it fits in the CRX bracket.
DA swaybars are cheap. its not that much more than stock. for some, like me and my street application, its a useful tweak in the right direction. when you get fast enough even on the track, bumping up the front swaybar a bit is also helpful and a weak front HF swaybar isnt enough anymore. its all about tuning.
i should remind you all that the DA swaybar is HOLLOW.
NovaRex
May 23, 2016 07:17 AM
japrex
Nov 29, 2004 04:49 PM
