For those of you that don't know what CTR pistons will look like in a TypeR block...
Old May 14, 2002 | 02:51 PM
FAST94GSR's Avatar
New User
Default For those of you that don't know what CTR pistons will look like in a TypeR block...
These are pretty damn high as you can see. Imagine this will a head milled 20 like I had...
Old May 14, 2002 | 02:54 PM
reefer_bob's Avatar
Default Re: For those of you that don't know what CTR pistons will look like in a TypeR block... (FAST94GSR)
Wow... Not much room for extra curricular activity in there...
Old May 14, 2002 | 02:56 PM
AssPenny's Avatar
Default Re: For those of you that don't know what CTR pistons will look like in a TypeR block... (reefer_bob
12:1 ownz j00
Thats what i'm doing the next time something major happens, screw warrenty and thouse bastard dealerships.
Old May 14, 2002 | 02:58 PM
FAST94GSR's Avatar
New User
Anyone want to take a stab at what my compression was?? You get a cigar if you win! I'm not even sure myself!
Old May 14, 2002 | 02:59 PM
Casey's Avatar
if i have those pistons, a mugen thin headgasket, would i have a problem with using jun3s?
AssPenny's Avatar
With 20mm? fawk i'm guessing realy close to 13 to 1 if not more What head gasket you running?
Old May 14, 2002 | 03:04 PM
FAST94GSR's Avatar
New User
yea i'm guessing 13:1 asspenny you get a prize!! The thing was a pig on gas to keep it from detonating. Pulled like a bich though..
To the guy asking the question with the jun cams and thinner headgasket, I wouldn't recommend it.. THose cams are BIG. You better make sure you have enough clearance before you throw it all in.. Do it right the first time.
Old May 14, 2002 | 03:08 PM
FAST94GSR's Avatar
New User
i ran a stock headgasket..cylinder temps would get so high the electrodes would burn off.
I don't recommend using a thin head gasket with those cams and those pistons..It should be fine but its wise to double check your clearances.
I am glad I dropped my compressoin down, I need some damn fuel economy now..I need a damn job too. arghh
Old May 14, 2002 | 03:18 PM
EagleR's Avatar
whatcompression would CTR pistons be w/o a milled head or thin gasket?
Pardon me if its a newbie q
D's Avatar
D
dood, does your car ever run?
Old May 14, 2002 | 03:23 PM
FAST94GSR's Avatar
New User
Default Re: For those of you that don't know what CTR pistons will look like in a TypeR block... (D)
It runs now that's all that counts. The f'ing block I bought was cursed from the get go..
Old May 14, 2002 | 03:24 PM
AssPenny's Avatar
I think if you just swap it out its like 12.1:1 That with spec B's... yummmmy
Old May 14, 2002 | 04:01 PM
azn98R's Avatar
I have JUN3's and I have plans to get the CTR pistons aswell. But I would be running on stock head gasket and no milling of the head. I should be ok right?
Old May 14, 2002 | 04:17 PM
Saga's Avatar
Just thought some of you might be interested in buying some CTR pistons...
https://honda-tech.com/zerothread?id=178670
Old May 14, 2002 | 04:46 PM
GQ 05YellowEVO8's Avatar
Default Re: For those of you that don't know what CTR pistons will look like in a TypeR block... (Saga)
I wonder how high the Toda Pistons reach ?
Old May 14, 2002 | 06:01 PM
canuck-mx6's Avatar
Default Re: For those of you that don't know what CTR pistons will look like in a TypeR block... (VTEC-MAN95
Here are my CTR pistons in my B18C1 block
I am running the JUN 3's, piston/valve clearance is fine. With an OEM 3 layer head gasket, compression is 12.1:1 and I have no detonation with 14 degrees base timing, fuel pressure at 45 PSI, RC 440 injectors and Hondata
[Modified by canuck-mx6, 3:02 AM 5/15/2002]
Old May 14, 2002 | 06:18 PM
AssPenny's Avatar
Got any plots/dyno numbers? Sound interesting... What cams are you running?
Old May 14, 2002 | 07:32 PM
Cams--> Toda Spec B's
Dyno numbers--> documented 188.5 WHP 131 Tq.
now with my newest mods maybe 192-193 WHP??
Old May 14, 2002 | 07:49 PM
How much did it cost you for the rebuild? Will Toda spec C's clear with a OEM headgasket?
drigotegi1234
135
Feb 14, 2009 11:41 PM
HamiltonRex
17
Feb 15, 2005 08:49 AM
Beezer
Dec 10, 2004 08:15 PM
GTEater
Sep 19, 2001 08:02 PM
junjun
10
Sep 12, 2001 06:48 AM
