Trailing arms...
Old Jan 8, 2007 | 02:04 PM
17's Avatar
17
Default Trailing arms...
Are the trailing arms for the Civic CX the same as the Del Sol Si or the Civic Si (92-95)?
I want to do a rear disk conversion. I have a thread in the "Want to Buy" for a set and someone quoted that the CX trailing arms may work as long as you break down the drum and its essentials.
Thanks man I appreciate all feedback, comments, disses or dogs, as long as I can get confirmation
Old Jan 8, 2007 | 02:05 PM
kaiba's Avatar
Default Re: Trailing arms... (17)
yes it fit.
Old Jan 12, 2007 | 03:46 PM
92greensleeper's Avatar
My man if your gonna do it you should do it the right way.....get the trailing arms from any 90s integra and the brake master off any early 90s ex or si. Voila. Oh and since you got the trailing arms you might as well get the sway bar too since the integra one is bigger.stainless steel lines never hurt either.
Old Jan 12, 2007 | 03:51 PM
gezzuzz's Avatar
Default Re: Trailing arms... (92greensleeper)
92-95 civic and 94+integras
are different then
88-91 civic/crx and 90-93 integras
im i wrong? if you have a eg you need to get parts from a dc,eg or ek (not EF and DC)
Old Jan 12, 2007 | 05:12 PM
BrakeExpert's Avatar
Default Re: Trailing arms... (gezzuzz)
88-00 Civic and 94-01 Integra trailing arms, bare, are 100% identical. Confirmed by me, the brake chart man.
Old Jan 12, 2007 | 05:16 PM
pdiggitydogg's Avatar
And the only difference between those arm and DA arms, is the larger TA bushings used in the latter.
Old Jan 12, 2007 | 05:40 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">92-95 civic and 94+integras
are different then
im i wrong? if you have a eg you need to get parts from a dc,eg or ek (not EF and DC)</TD></TR></TABLE>
You mean the front brakes knuckles. Rear trailing arms are the same.
Old Jan 12, 2007 | 08:09 PM
JShull's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">And the only difference between those arm and DA arms, is the larger TA bushings used in the latter.</TD></TR></TABLE>
This man speaks the truth.
Old Jan 14, 2007 | 08:16 PM
17's Avatar
17
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JShull &raquo;</TD></TR><TR><TD CLASS="quote">
This man speaks the truth. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
You mean the front brakes knuckles. Rear trailing arms are the same. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">And the only difference between those arm and DA arms, is the larger TA bushings used in the latter.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline57 &raquo;</TD></TR><TR><TD CLASS="quote">88-00 Civic and 94-01 Integra trailing arms, bare, are 100% identical. Confirmed by me, the brake chart man.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">92-95 civic and 94+integras
are different then
im i wrong? if you have a eg you need to get parts from a dc,eg or ek (not EF and DC)</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92greensleeper &raquo;</TD></TR><TR><TD CLASS="quote">My man if your gonna do it you should do it the right way.....get the trailing arms from any 90s integra and the brake master off any early 90s ex or si. Voila. Oh and since you got the trailing arms you might as well get the sway bar too since the integra one is bigger.stainless steel lines never hurt either.</TD></TR></TABLE>
I appreciate all feedback and help! Thanks guys. Anyone else want to add to this that'd be great.
If I use Integra rear brakes then I want to use 94-up? Thats including the sway bar and master cylinder?
Thanks!
De_tour
44
Feb 1, 2008 10:49 PM
UmbraDc2K
Oct 6, 2007 11:24 AM
Bictorious
Mar 18, 2004 03:39 PM
rags2riches
Jul 25, 2003 03:05 PM
tony415
Dec 19, 2002 11:09 AM
