15x6.5 +42 fit on '96 DX Coupe?
Old Jan 8, 2007 | 12:33 PM
Fate's Avatar
Default 15x6.5 +42 fit on '96 DX Coupe?
I'm looking into buying a set of wheels. The specs on the wheels are 15x6.5 with a +42 offset. I'm just wondering if these will work ok on my '96 DX Coupe.
Old Jan 8, 2007 | 06:38 PM
vtecsi00's Avatar
Default Re: 15x6.5 +42 fit on '96 DX Coupe? (EGRacersInc)
they will fit no problem
Old Jan 8, 2007 | 09:23 PM
bmoua's Avatar
Default Re: 15x6.5 +42 fit on '96 DX Coupe? (vtecsi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">they will fit no problem</TD></TR></TABLE>
yep...you'll rub if you slam it but you'll be okay...i have 15x7's i believe with a 40 offset with 205/50/15's and they rubbed but had to roll my fenders a little to fix that problem.
Old Jan 9, 2007 | 08:24 AM
vtecsi00's Avatar
Default Re: 15x6.5 +42 fit on '96 DX Coupe? (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">
yep...you'll rub if you slam it but you'll be okay...i have 15x7's i believe with a 40 offset with 205/50/15's and they rubbed but had to roll my fenders a little to fix that problem.</TD></TR></TABLE>
the reason why you rub is that you are running the wrong size tire if you own a 1996 civic or older....you should have a 195/50r15 and then they wouldn't rub at all.... and that is the size you need as well EGRacersinc
Old Jan 9, 2007 | 09:16 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">the reason why you rub is that you are running the wrong size tire if you own a 1996 civic or older....you should have a 195/50r15 and then they wouldn't rub at all.... and that is the size you need as well EGRacersinc</TD></TR></TABLE>
vtecsi00 is correct. It's also worth noting that the proper 15" size in '96 depends on the model of Civic. The DX and hatchback '96 models (like EGRacer's) need 195/50-15, as vtecsi00 noted. All other '96 Civic models need 205/50-15 or 195/55-15.
kaluwa3
Jul 17, 2008 11:41 AM
FuLlRaCe XLR8R
11
Aug 24, 2007 06:43 AM
Boostage
Apr 25, 2005 07:59 PM
Bull
Dec 10, 2004 01:30 PM
FrostyDC4
Oct 1, 2004 05:40 PM
