power window wiring!!!
Old Jan 8, 2007 | 12:20 PM
dump3deg6's Avatar
Default power window wiring!!!
okay, im like completly lost on this. i bought some power windows off some dude, but his car was all rigged for them to work, so i took what i thought was salvagable. but im basicly missing the entire harness.. which sucks. But has anyone wired up power windows without using the harness? I neeed a wiring diagram for the switches (on door) so i can figure out what wire is what.. and yes, ive searched for the passed 2 days..
so if anyone can help, or has the diagram, please post it
this is for a 95 cx hatchback
Old Jan 8, 2007 | 01:11 PM
Relic1's Avatar
this should help you out a little. http://www.b18c5eg.com/2d-3d%2....html
I wrote it up a while ago when I did mine the same way (OEM window regulators and switches but no harness)
Old Jan 8, 2007 | 01:18 PM
dump3deg6's Avatar
wow realllllly confusing
Old Jan 8, 2007 | 01:27 PM
dump3deg6's Avatar
i think i got it tho.. you have to hook up both doors before you see if they work correct?
Old Jan 8, 2007 | 01:31 PM
dump3deg6's Avatar
okay im lost on where you put thr 12 volt source, what pin is that? what pin do u put power to
Old Jan 8, 2007 | 01:35 PM
Relic1's Avatar
Default Re: (dump3deg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dump3deg6 &raquo;</TD></TR><TR><TD CLASS="quote">wow realllllly confusing</TD></TR></TABLE>
not really for the weak at heart...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dump3deg6 &raquo;</TD></TR><TR><TD CLASS="quote">i think i got it tho.. you have to hook up both doors before you see if they work correct?</TD></TR></TABLE>
correct. the passenger side gets it's ground from the driver's switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dump3deg6 &raquo;</TD></TR><TR><TD CLASS="quote">okay im lost on where you put thr 12 volt source, what pin is that? what pin do u put power to</TD></TR></TABLE>
the 12V comes from the underdash fuse box. the pins normally used are on the rear of the fuse box. That pulls power from the built in relay and accessory connections.
But you don't have to use that, any relay'd accessory power connection is fine. (ie accessory power turns on the relay)
Old Jan 8, 2007 | 03:45 PM
dump3deg6's Avatar
Default Re: (Relic1)
Okay pass side only roll up from the switch, and drivers side switch won't do anything to pass side window. .what could be the prob? I hooked it up exactly as you described. Drivers side rolls up and down tho.. I'm lost!
Old Jan 8, 2007 | 04:28 PM
dump3deg6's Avatar
Hey relic. Hit me up on aim, I wanna ask u a few questions.
Dump3deg6 is my aol screen name
Old Jan 8, 2007 | 05:49 PM
dump3deg6's Avatar
Prob fixed. Thanks!!!!!!!!
soLaLive
Feb 26, 2012 10:48 AM
import-tooner
Aug 25, 2010 10:12 AM
DA-9mordef
Apr 26, 2006 04:50 AM
projektvtec
10
Sep 25, 2005 07:42 AM
