more power, less money
Old Jan 8, 2007 | 11:40 AM
Synyster 7X's Avatar
Default more power, less money
what are the best engine mods i can bolt onto my 99 civic dx d16y7 to get more power? already have a cold air intake and an axel back exhaust, soon to be getting headers and underdrive pulleys. i've seen websites say that upgrading the ignition components and fuel delivery systems are necessary but i think they might be just going for the sale. turbo and nitrous is out because i cant spend that much money. just want simple bolt on mods that can get me more hp. i've been considering:
Intake Manifold
Throttle Body
Throttle Body Spacer
Iridium Spark Plugs/Wires
High Flow Fuel Rail
Ignition System
Fuel Injectors
if some one could help me out by telling me which of these are worth the money and suggest any others, i would greatly appreciate it.
Old Jan 8, 2007 | 11:43 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: more power, less money (Synyster 7X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synyster 7X &raquo;</TD></TR><TR><TD CLASS="quote">what are the best engine mods i can bolt onto my 99 civic dx d16y7 to get more power? already have a cold air intake and an axel back exhaust, soon to be getting headers and underdrive pulleys. i've seen websites say that upgrading the ignition components and fuel delivery systems are necessary but i think they might be just going for the sale. turbo and nitrous is out because i cant spend that much money. just want simple bolt on mods that can get me more hp. i've been considering:
Intake Manifold
Throttle Body
Throttle Body Spacer ----------Waste of money
Iridium Spark Plugs/Wires------Iridums are not necessary, get copper NGK V-powers along with NGK wires
High Flow Fuel Rail----------Waste of money
Ignition System
Fuel Injectors----------Waste of money
Even with IM/TB you won't really see any big gains. Honestly, I'd just save up for a Y8 swap or something better. Then turbo or build it for N/A, depending on whatever route you'd rather go.
Old Jan 8, 2007 | 11:47 AM
doood's Avatar
been there done that
Default Re: more power, less money (SkoundrelUSA)
bolt on's, no matter what they are, arent going to give you any kind of noticeable hp gains especially with that engine.
Old Jan 8, 2007 | 11:48 AM
Syndacate's Avatar
mini-me swap.
Just FYI, D series motors suck for naturally aspired hp.
Old Jan 8, 2007 | 11:49 AM
JShull's Avatar
Honestly. For your money. Change the tranny. One from an EX/Si.
Or to get any real power. The ones you listed will be lacking. Piece together a turbo kit. I know you say it is out of the question but think about it. All of that stuff listed won't do isht.
Your ignition is fine. The fuel rail is good to like 400hp. If you want to get down to it the fuel injectors, IM, throttlebody are putting you on your way to that turbo kit you could slowly put together.
The pulleys and the header you just bought...ran how much? That stuff will gain you less hp than you can count on both of your hands. Just a thought.
Syndacate's Avatar
PS: Your problem is the one that's been plaguing Civic owners since '92.
No way around it, you want a strong motor, you need FI. Or you can drop an assload of cash on a NA D-series build, probably run 160whp max, and only use it at the track :-\.
There is no MORE power for LESS money unless you boost. Simple as that.
I wish there was another way, so do 1000's of other pple, but there isn't.
Welcome to the world of 4 bangers.
Old Jan 8, 2007 | 04:17 PM
Default Re: (Syndacate)
when you say piece together a turbo kit what exactly do you mean? i did recently consider a turbo kit until i discovered the cost of the kit and installation and computer recalibration would run as high as $5500. If i had that kind of money i would buy a whole new car. if you have a lower cost alternative please let me know. (can't possibly install it myself)
Old Jan 8, 2007 | 04:19 PM
Turbo_y8's Avatar
Default Re: (Synyster 7X)
boost
Old Jan 8, 2007 | 04:24 PM
jtchinoy's Avatar
can run AS HIGH AS $5500
Do your research home made turbo kit... meaning get the pieces yourself... you can put a decent one together for as low as $600. Depending which way you go you can buy emanage or you can obd1 convert and hondata or crome or uberdata so you can turbo if you do your homework for as low as $1300 tuned i'd say? $2000 I'd say you can get a pre assembled turbo kit and get a decent tune done.
Old Jan 8, 2007 | 04:32 PM
big-cat's Avatar
hell dood it can cost 239847238904723 dollars if u pay for it. if your just getting your feet wet into the turbo seen your going to be ran back about 1500, which isnt that bad. you could piece a very nice kit together with that money or you can buy a small greddy kit that will have everything u need.(going to need to swap out your IM though or do a customization with one pipe so it will fit on the Y7 IM) other than that it comes with directions and the whole she bang and more than likely be able to beat b-series motors, with a stock greddy kit. but its the only thing u can do for that motor. http://www.turbod16.com and
http://www.homemadeturbo.com those websites should help
p.s. either or your going to need to do a bit of research but it should be worth it in the end.
Old Jan 8, 2007 | 04:33 PM
Default Re: (jtchinoy)
$1300 tuned and ready to drive? you've got to help me out on taking this route. do your homework doesn't help, that's why i'm posting here, this is my homework. if you could elaborate more on how to get a functional turbo onto my car for $1300 i'd appreciate it.
Old Jan 8, 2007 | 04:35 PM
big-cat's Avatar
we arent going to do the work for you, u need to look it up and research it just like we did, sorry the baby sitter is off duty.
its not hard. just look at some of my websites and if you want a greddy kit just look around.
Old Jan 8, 2007 | 04:45 PM
trrbl1bmx's Avatar
turbo d series is cheap son.... you must do research
Old Jan 8, 2007 | 04:51 PM
Syndacate's Avatar
Default Re: (big-cat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big-cat &raquo;</TD></TR><TR><TD CLASS="quote">we arent going to do the work for you, u need to look it up and research it just like we did, sorry the baby sitter is off duty.
its not hard. just look at some of my websites and if you want a greddy kit just look around.</TD></TR></TABLE>
Yeah that's basically it.
For 1500 or so you could buy the parts for a very nice turbo kit.
The tune is separate, though some pple street tune and are fine.
Old Jan 8, 2007 | 04:57 PM
Turbo_y8's Avatar
when i first boosted it ran me about $1700
Old Jan 8, 2007 | 05:00 PM
cute little bastard
Try reading this
https://honda-tech.com/zerothread/1024174
Old Jan 8, 2007 | 05:03 PM
deadline's Avatar
buy a N.O.S. kit ............problem solved...500$
Old Jan 8, 2007 | 05:09 PM
Turbo_y8's Avatar
Default Re: (deadline)
nit. is ok but, a car/motor should be built around nit. a car with just a shot of nit is still slow besides that. but a motor built around nit. could be a different story.
Boost is still your best bet for all around power.
Old Jan 9, 2007 | 07:53 AM
should i stay away from SSAUTOCHROME turbo products?
Old Jan 9, 2007 | 08:02 AM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synyster 7X &raquo;</TD></TR><TR><TD CLASS="quote">should i stay away from SSAUTOCHROME turbo products?</TD></TR></TABLE>
YES! STAY AS FAR AWAY AS POSSIBLE
Old Jan 9, 2007 | 08:12 AM
Default Re: (SkoundrelUSA)
what about used turbochargers, wastegates, intercoolers, etc? good or no good?
Old Jan 9, 2007 | 08:15 AM
cute little bastard
I myself have never used any of their products, but almost every month someone makes a new thread saying something bad about their products/service. do a search for "ssautochrome" and the first top 10 are "warning" threads lol
Old Jan 9, 2007 | 09:06 AM
JShull's Avatar
Used turbos, wastegates, intercoolers are usually fine. Junkyard turbo D ftw.
Old Jan 9, 2007 | 09:49 AM
Bense's Avatar
ex trans, y8 intake manifold
Old Jan 9, 2007 | 04:08 PM
Default Re: (Turbo_y8)
i'm not seeing d series greddy turbo kits for anthying under 2500. the cheapest ones i've seen only fit ex and si. no sites i've come across carries kits that will fit my year and trim level for a reasonable price. does anyone know where to find these rare kits?
