no vtec
Old Jan 8, 2007 | 09:31 AM
joethejoeman's Avatar
Default no vtec
i have a b16 in my rex and there is no vtec,
i cleaned the screen, i got a new vss, i have a vafc2 bc im runing obdo and it still not kicking in, only code 21,
any other suggestions?
Old Jan 8, 2007 | 09:33 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: no vtec (joethejoeman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joethejoeman &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16 in my rex and there is no vtec,
any other suggestions?</TD></TR></TABLE>
Are you fully warmed up?
in a foward gear?
Whats your oil pressure ?
whats 21 again? the cold medicines I took are killing my memory.
Old Jan 8, 2007 | 09:37 AM
wiZCo's Avatar
Stouts 'n' Scotch
VTEC engagement point on VAFC?
Old Jan 8, 2007 | 09:45 AM
Default Re: no vtec (wiZCo)
it was 5900 and that wasnt working,
so i changed it over to 4500 for hi cam still dosent work,
Old Jan 8, 2007 | 09:46 AM
it is warmed up,
the oil pressure should be good bc thats code 22,
and code 21 is the vss
Old Jan 8, 2007 | 09:47 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joethejoeman &raquo;</TD></TR><TR><TD CLASS="quote">it was 5900 and that wasnt working,
VAFC wired correctly? Also try taking it out of the loop just incase.
I'm not a fan of VAFC at all and 4500 seems quite low to try at.
Old Jan 8, 2007 | 09:50 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: no vtec (Capt. Blonde Beard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Capt. Blonde Beard &raquo;</TD></TR><TR><TD CLASS="quote">
I'm not a fan of VAFC at all and 4500 seems quite low to try at.</TD></TR></TABLE>
Agreed. Try it back around "stock" levels (~5K) and clear up that VSS code.
Old Jan 8, 2007 | 09:53 AM
could it be the oil even though it is not throwing a code,
ill change it back to 5900
Old Jan 8, 2007 | 09:54 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joethejoeman &raquo;</TD></TR><TR><TD CLASS="quote">could it be the oil even though it is not throwing a code,
ill change it back to 5900</TD></TR></TABLE>
why is it at 5900? What cams do you have in it?
Old Jan 8, 2007 | 09:57 AM
stock cams the ones in the b16a1
Old Jan 8, 2007 | 09:58 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joethejoeman &raquo;</TD></TR><TR><TD CLASS="quote">stock cams the ones in the b16a1</TD></TR></TABLE>
That's probbly too high then, aim for like 5100.
JdM_RACeR07's Avatar
What gas do you have in it???? If its not premium it wont engage
Old Jan 8, 2007 | 10:00 AM
Default Re: no vtec (JdM_RACeR07)
ialways use 91 mixed w\ either 110, or octaine booster,
but if it would kickin at 5100 wouldnt it just do that when set at 4500 but just wait till it hit 5100 or would it quit telling it to kick over ??
Old Jan 8, 2007 | 10:01 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM_RACeR07 &raquo;</TD></TR><TR><TD CLASS="quote">What gas do you have in it???? If its not premium it wont engage</TD></TR></TABLE>
Wrong don't spread bull **** kthx.
You shouldn't but that is flat out wrong, more then one time have i hit vtec with 87, yea long story short don't let your g/f borrow your car.
Old Jan 8, 2007 | 10:02 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joethejoeman &raquo;</TD></TR><TR><TD CLASS="quote">ialways use 91 mixed w\ either 110, or octaine booster,
but if it would kickin at 5100 wouldnt it just do that when set at 4500 but just wait till it hit 5100 or would it quit telling it to kick over ??</TD></TR></TABLE>
Don't waste your time with octane booster...
Can you please repharse what you say?
Old Jan 8, 2007 | 10:06 AM
What i Tried to say was when it is set at a point (like 4500 for ex.) and if it dosent kick over at that point, does it keep trying to kick over, like by the time it got up to 5100, or after 4500 would it just stay with low cams and not try to kick over again
Old Jan 8, 2007 | 10:07 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joethejoeman &raquo;</TD></TR><TR><TD CLASS="quote">What i Tried to say was when it is set at a point (like 4500 for ex.) and if it dosent kick over at that point, does it keep trying to kick over, like by the time it got up to 5100, or after 4500 would it just stay with low cams and not try to kick over again</TD></TR></TABLE>
If it tosses a code it will not trying changing over again.
Old Jan 8, 2007 | 10:09 AM
It wasnt working b4 i had the Vafc, so do you think that it could be something else?
Old Jan 8, 2007 | 10:10 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joethejoeman &raquo;</TD></TR><TR><TD CLASS="quote">It wasnt working b4 i had the Vafc, so do you think that it could be something else?</TD></TR></TABLE>
Have you had the shot to swap ECUs?
Old Jan 8, 2007 | 10:14 AM
no i havent
Old Jan 8, 2007 | 10:15 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joethejoeman &raquo;</TD></TR><TR><TD CLASS="quote">no i havent </TD></TR></TABLE>
If you can give it a wihrl. I'm running low on ideas other then a dead solinoid low oil pressure and a few other things.
Old Jan 8, 2007 | 10:19 AM
ive been using 5w20 oil, would that make a diff.
i belive taht is the right oil
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joethejoeman &raquo;</TD></TR><TR><TD CLASS="quote">ive been using 5w20 oil, would that make a diff.
i belive taht is the right oil</TD></TR></TABLE>
5-20 is a bit light, 5-30 is probbly better.
But shouldn't effect vtec engament.
Old Jan 8, 2007 | 10:22 AM
what oil pressure is it supose to be at,
i dont have an oil pressure gage, but if it means working vtec i can take a shot at going take it to the shop to find out,
Old Jan 8, 2007 | 10:27 AM
[QUOTE=Capt. Blonde Beard]
wellllll its right with my baby...93 gsr.....wouldn't engage after a swap with regular gas so i figured maybe its just not warm enough after abotu a 10 minute mashing drive still nothing....someone on HT said it wont engage without premium so i took it to the gas station filled her up with premium and i pulled out the the driveway in my little rex then next thing i know i was slammed to my seat cuz i wasn't expecting it.....so its not bullshit premium is the engager atleast for my swap
