Are SI brakes and calipers the same size as Integra LS/RS brakes and calipers?
Old Jan 8, 2007 | 09:27 AM
tofu man's Avatar
Default Are SI brakes and calipers the same size as Integra LS/RS brakes and calipers?
I'm looking to put a set of 14in wheels on the Civic. The 14in civic special edition wheels are currently on my Integra with no problem.
My question as stated in the title is are SI Brakes and Calipers the same size as Integra LS/RS Brakes and calipers?
I know HX wheels will not fit on a si and they are 14's, but the HX will not fit because of the offset.
The wheels that I have came stock on a civic. They were a package that had to be ordered.
I am trading someone for the 14's but I really don't want to drive 4 hours to find out my wheels wont fit on his car.
Old Jan 8, 2007 | 09:52 AM
MasterKwan's Avatar
Default Re: Are SI brakes and calipers the same size as Integra LS/RS brakes and calipers? (cw.tech)
The civic EX/SI and Integra's all use the same brake rotor sizes. The CX/DX use smaller brakes so, they can use smaller wheels. The calipers are different on the Integra's and Civics.
Old Jan 8, 2007 | 09:56 AM
tofu man's Avatar
Default Re: Are SI brakes and calipers the same size as Integra LS/RS brakes and calipers? (MasterKwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">The civic EX/SI and Integra's all use the same brake rotor sizes. The CX/DX use smaller brakes so, they can use smaller wheels. The calipers are different on the Integra's and Civics. </TD></TR></TABLE>
So will the 14's fit on the SI, thats my question
EL Vap133's Avatar
Yes, 99-00 Si brakes are the same size as Integra brakes. If I remember correctly they only difference is the caliper piston beingslightly bigger for the Integra.
Old Jan 8, 2007 | 10:02 AM
tofu man's Avatar
Default Re: Are SI brakes and calipers the same size as Integra LS/RS brakes and calipers? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, 99-00 Si brakes are the same size as Integra brakes. If I remember correctly they only difference is the caliper piston beingslightly bigger for the Integra. </TD></TR></TABLE>
Thats what I was thinking, but GSR brakes are bigger than mine. Are SI brakes as big as a GSR?
Here are some pics
Anyone else feel the same or have any info?
Old Jan 8, 2007 | 10:15 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cw.tech &raquo;</TD></TR><TR><TD CLASS="quote">
Here are some pics
Anyone else feel the same or have any info?</TD></TR></TABLE>
YES, SI BRAKES ARE THE SAME SIZE! If your brakes are not the same size as GSR/LS brakes then you don't have 99-00 Si brakes. You might have the Eg Si brakes instead.
Old Jan 8, 2007 | 10:16 AM
tofu man's Avatar
YES, SI BRAKES ARE THE SAME SIZE! If your brakes are not the same size as GSR/LS brakes then you don't have 99-00 Si brakes. You might have the Eg Si brakes instead. </TD></TR></TABLE>
no no, I have the Integra. Thanks!
Old Jan 8, 2007 | 10:54 AM
MasterKwan's Avatar
Tape measure will answer all questions. All you need to know is whether a wheel will fit a stock EX/SI/Integra and if the answer's yes, it'll fit your car.
10.4" is the rotor diameter I believe. Even the GSR uses the 10.4" rotor. The Integra R rotors are 11" as are the Prelude and Acura Legend. R/Lude/Legend rotors require a 15" wheel.
The Civic and Integra calipers are quite different and use different mounting brackets. It's the caliper that has to clear so, I just thought I'd throw that out there. I'm pretty sure any 14" wheel for a honda will work on the 10.4" brakes.
gogetta
Nov 9, 2008 05:59 PM
253EK
Nov 8, 2007 09:19 PM
tommyz32
May 21, 2005 08:38 AM
piscorpio
Nov 20, 2002 07:00 PM
