question about rear sway install on 94 hatch
Old Jan 8, 2007 | 08:00 AM
JDM_dreamer's Avatar
Default question about rear sway install on 94 hatch
i just purchased a blox rear sway bar, end links and the chassis re-enforcement from blix. now im sitting here wondering if i can even install it. i don't think my car has a sway bar, which means i wont have the mounts for it correct? if that is the case, what car/chassis could i take these from to mount up correctly?
thanks in advance.
Old Jan 8, 2007 | 08:12 AM
eg6sir-s's Avatar
Default Re: question about rear sway install on 94 hatch (JDM_dreamer)
i hope the blox kit comes with instructions as well as you ordering one for a non-rear sway bar 1992-95 civic.
if the kit comes with instructions take it one step at a time. gather up all the tools you need and the rest should fall into place
Old Jan 8, 2007 | 08:16 AM
DelSolMarine's Avatar
Default Re: question about rear sway install on 94 hatch (eg6sir-s)
im not sure but mayb u need new rear control arms
Old Jan 8, 2007 | 08:23 AM
grayegcivic's Avatar
you need an aftermarket lca or the ones from 94-00 integra(not that sure) coz our cars doesnt came with the sway bar mounting hole on the lca. Thats all you need!
Old Jan 8, 2007 | 08:25 AM
Default Re: question about rear sway install on 94 hatch (grayegcivic)
ohhhhh i didnt no that. thanks for the heads up. what about the 2 brackets that hold the sway bar to the chassis? should those come with the new sway bar or do i need to sorce them from somewhere else?
Old Jan 8, 2007 | 09:19 AM
Default Re: question about rear sway install on 94 hatch (JJSpecTuning)
actually i don't need em, at the same time im doing my suspension and a gsr rear disk swap, and it comes with the LCA's. thanks for the offer though.
Old Jan 8, 2007 | 08:17 PM
Dann6968's Avatar
So everyone knows, there are a few companys that make sway bars for civic w/o holes in the LCA's for the end links. The end links bolt to the bottom of the shock/LCA bolt.
Civichatch2k
Suspension & Brakes
Feb 1, 2009 11:50 AM
carrnut21
Dec 12, 2006 07:40 PM
EJ1 wilcox
Suspension & Brakes
23
Mar 14, 2006 12:49 PM
$LiLPooky$
Oct 6, 2005 09:48 AM
Andrew 825SM
Jul 7, 2003 01:19 PM
