I need Auto trans Gurus help. 92 accord.
Old Jan 7, 2007 | 09:55 PM
Juan Q...'s Avatar
Default I need Auto trans Gurus help. 92 accord.
I have a 92 Accord and the trasn went bad. I bought a used one from the junkyard and put it on. It drove about 5 miles and it did the same thing ( When I put it in park while its running it makes a loud grinding noise sorta like when you put a basaball card on a biycle wheel) and it wont go into any of the gears. I put cheap fluid in it so I wouldnt spend too much on it plus i was gonna change it the next day. could that have been the problem? I replaced that one and got another one and it did the same thing. WTF? Any help or insight would be great. Im tired of changing that damn trasnmission.
Old Jan 7, 2007 | 10:10 PM
YeuEmMaiMai's Avatar
Default Re: I need Auto trans Gurus help. 92 accord. (Juan Q...)
drive shaft maybe?
Old Jan 8, 2007 | 08:26 AM
Juan Q...'s Avatar
Default Re: I need Auto trans Gurus help. 92 accord. (YeuEmMaiMai)
2 teasnmissions have done the same thing. any ideas?
Old Jan 8, 2007 | 01:05 PM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">drive shaft maybe?</TD></TR></TABLE>
What a dufus !!
Old Jan 11, 2007 | 02:34 PM
Davids92Accord's Avatar
i guess your best bet would be to convert to manual dude cause i went through 2 auto trannys they were giving my problems like crazy and i didnt even race the damn car your better off converting it to stick it was worth it i can tell you that
Old Jan 11, 2007 | 06:35 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: I need Auto trans Gurus help. 92 accord. (Davids92Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davids92Accord &raquo;</TD></TR><TR><TD CLASS="quote">i guess your best bet would be to convert to manual dude cause i went through 2 auto trannys they were giving my problems like crazy and i didnt even race the damn car your better off converting it to stick it was worth it i can tell you that </TD></TR></TABLE>
well that's a silly fix to the problem
I bet you need to adjust your shifter cable. That may have been the problem all along.
Old Jan 12, 2007 | 09:56 AM
Default Re: I need Auto trans Gurus help. 92 accord. (Ross 4107)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 4107 &raquo;</TD></TR><TR><TD CLASS="quote">
well that's a silly fix to the problem </TD></TR></TABLE>
yea well the problems i had with my tranny was no loose or out aligned shifter cable thats for sure and plus maintaning a auto tranny is more expensive cause its more sensitive than a 5 speed
4g4dcruisin
Sep 19, 2016 03:15 AM
endless22
Dec 8, 2011 10:35 PM
dan200
Nov 14, 2007 01:51 PM
turbocivic0618
May 4, 2006 01:55 PM
